Beachboys in the Netherlands, Zandvoort
Watching.
Tennis court Heemstede.
Shot from the inside of the camera shop, while trying the 16-55  :)
Foggy morning.
xe2 18/55
Bamberg, Germany.
xe2 50/230.
Black Sea, Abhazia, XE-2, LR
    • (Open Thread) Not a winter landscape, but still cold.
    • agreed on the upload but based on the location and number it sounds exactly like the storage slot 1 status icon
