More life... instagram @lifewithlouis
Coronatimes, August 2020 - Toronto
XH1 + 16-55MM
Edited by lifewithlouis
  • 4 months later...
  • 9 months later...
From the County Fair
Fuji X-Pro3
XF 16-80mm f/4 @ f/4
Shot raw processed in darktable.
Fujifilm XF10. Shot in Cologne/Germany.
  • 3 years later...
xt50 + 23mm f2
GFX100RF   17 sec.   f16   160 ISO
GFX100RF  160 ISO   f11    7 sec.
Halloween display in a local park.
