Another one. Near Probolingo, Indonesia. XT-1 with 18-135.
Gibraltar Lighthouse
Fuji XE-2
10-20mm
Cliffs in Pría (Asturias, Spain)
Fuji X-E2 + XF 18-55 processed in Camera Raw + PS
Carrascar de la Font Roja, Alcoy (Spain)
X-E2 + XF 18-55
I was on a short trip to Austria this weekend and managed to sqeeze in a little time for shooting:
This was at the Franconia Notch State Park. The view from the top is brilliant !
Dinosaur coast, Asturias (Spain)
