Snowy Owl captured in central Ontario, Canada in the middle of the winter.
Just fooling around with the 55-200  B)
Walking in the park with my X100S… spotted this lil fella.
55-200 @ 200 + crop
Cupido
(X-A1, XC 50 - 230 @ 230mm, f 6.7)
Home or Captivity?
(Shot with X-T1 and a Nikon 300mm manual lens)
