Here you can post your night photographs (done with Fuji X cameras, of course!)
This includes all kinds of night photography, from night portraiture to star trails and even time lapse.
To prime the topic: Fuji X-T1, 55-200, 3 small strobes. Minimal post processing.
Doing great folks, keep it up!  :D
Fuji X-T1, 10-24/4, large octabox. SOOC.
Lightstream
Game on!
This was shot just after sunset.
XT-1, 18-55, Handheld, SOOC JPG
Swiss Alps, Valais
Lightstream II
city lights...
xe2, xf56, f1.2
a small off-topic comment.
such "long" series as in post #23 for me are cumbersome to look at and to appreciate.
If all the pics really belong together to a mini series ... ok, why not ... but just a bunch pf pics for the same topic ...
(just my opinion)
beside that: #23 contains nice pictures :-)
