Yes, gradient is like using a graduated filter on the lens
My favourite method for converting Color photos to B&W, has to be Photoshop Gradient map. I watched a video which walked through about 8 different methods, but the gradient map seemed to retain the largest tonal range of colors when converted into B&W. I shoot 100% of my photos in color, but end up converting a lot to B&W in post. Usual method is to fully edit for color in Lightroom, transfer to Photoshop only to apply the "Gradient Map", then bring it back to lightroom and adjust levels to taste.
Here's an example of the look when finished:
I've tried just editing in Lightroom by switching to the B&W panel, but for some reason it often reduces the overall tonal range of colors. Gradient map is visibly better, every time (and it's a very simple conversion!)
Edited by lleo
There's the Gradient Filter / Radial filter from Lightroom and Photoshop that adds the Graduated Filter, like the ones attached to lenses.
Gradient Map is an adjustment layer in Photoshop which converts your image into a gradient based on the two colors you choose. This Gradient Map Tutorial is a great resource to teach how it is done!
Edited by Isaac Hilman
Some landscapes from my last trip to Japan, Australia and USA:
32438926152_06e7e30995_h.jpgShadows in the Valley @Red Rock Canyon, Nevada, USA by Hendrik Osula, on Flickr
X-T1 + 50-140/2,8
31748085994_a582e9c75c_h.jpgCamping Under Stars @Buffalo Mountains, Australia by Hendrik Osula, on Flickr
X-T1 + 14/2,8
32468796511_fc39c1f025_h.jpgSheep @Victoria, Australia by Hendrik Osula, on Flickr
X-T2 + 50-140/2,8
32212544280_2be4dadde0_h.jpgGreen Valley @Victoria, Australia by Hendrik Osula, on Flickr
X-T2 + 50-140/2,8
32212541740_50b24730c7_h.jpgTwelve Apostels @Victoria, Australia by Hendrik Osula, on Flickr
X-T1 + 14/2,8
very nice, you Sir are a very fine photographer.
I like the good use of the compressed view of a tele for landscapes with trees and the meadows with the sheep, the one with trees I would have enhanced contrast a little ( or maybe go the other way around) to deal differently with the haze in the background.
Thank you for compliment, I'm really glad to hear that!
On the picture with trees I tried to find best balance between shadows and highlights and you might be right, that I should have went for darker shadows and higher contrast. Will try it when all other photos are ready :)
Actually, I like that shot the way it is, more natural and makes me feel like I'm there.
Oddly, I found the processing on the last one a little noticeable, but love the shot.
Loved those shots, though, and totally agree about using telephoto for landscapes, not done enough!
A small fishing village. Xpro2  23/2.8
Takasphoto - I really enjoyed your photostream. Just so you're aware, though, the above post isn't showing the picture correctly on this thread, just a lot of code, might be worth correcting the link?
Thank you, I think I fixed it - excuse me, it was my first post ever on this forum.  And I appreciate your help!
32711570992_a1c573a469_h.jpgCold Morning @Kollassaare, Estonia by Hendrik Osula, on Flickr
X-T2 + 90/2
32483936610_45799f5534_h.jpgSunset @Saare, Estonia by Hendrik Osula, on Flickr
X-T2 + 23/1,4
32711569362_2b54a1abc4_h.jpgCold Morning @Kollassaare, Estonia by Hendrik Osula, on Flickr
X-T2 + 18/2
32823836016_c7c65b1b66_h.jpgCold Morning @Kollassaare, Estonia by Hendrik Osula, on Flickr
X-T2 + 18/2
Going colour crazy at Railay Beach after sunset 9 days ago....
X-T1, Samyang 12mm f/2.0
Edit: BTW if someone knows the model let me know... I was shooting the sunset, didn't have my portrait lenses, and she arrived with another photographer and stood in front of my composition (had the tripod installed and all), so I continued shooting, she was sort of hidden behind the boat, but on one moment the waves made the left boat turn and I had the shot ;)... and as fast as they appeared, they were gone so couldn't ask for their email to send them the pic, and on the camera LCD she was mostly on silhouette so they wouldn't be so thrilled neither if I showed them the shot then.
Edited by Biuti Chile
    • Yes Is some small amount leftover from the spot i cleaned. Inside only very less point of dust,yes my be are from manufacture Is very microscopic. anyway on pictures i not see dust and i not see the spot i clean. thankyou so much for your reply Is beautiful im Happy.Have a good day
    • Are you certain the spot is on the inside and not some small amount leftover from the spot you cleaned? Maybe try a different brand of lens cleaner, but make sure it is safe for lenses so that the lens coatings are not removed. Even weather resistant lenses can get dust inside, the seals can only keep out so much dust and zoom lenses are known to get dusty on occasion. More so than prime lenses do. Weather resistant means more sealing, but achieving perfect sealing is tough to get. It is also possible the dust has been there from the time it was manufactured and you are only now noticing because of the white dot. Does the dust show up in any of your photos? As far as cleaning cost goes, your local camera repair shop will be able to give you some estimates, prices will be different depending on where you are.
    • You may have to wait for next Easter and try again then.
    • Hello, After a long travel i see a micro white point on lent. I try with a product clean but not gone. After i try 50 time very gentle in many days. The micro point are gone but still a micro micro point. The lent Is 16/80 fuji. After  if i look lent in the direct sun i can see some micro points of dust. Very less but the lent on paper Is water resistent. So how can have micro point of dust inside? Anyway how i can clean or where i can go for clean my camera and how much can costly? Thankyou everyone
    • Update: the camera seems to have self-corrected. 🤷‍♂️  My working hypothesis is that moisture caused it to glitch, and after drying out, it's working again.
