The dynamic range of shooting raw.
Middle of the night, 27mm f/2.8, Melbourne Australia.
Just a silhouette. X-T1, XF56mm, Velvia simulation.
Night Shot at Shuttleworth
View from Hotel Glymur in Saurbaer, Iceland
Hamburg - World Cultural Heritage
"The Speicherstadt (German pronunciation: [ˈʃpaɪ̯çɐˌʃtat], literally: 'City of Warehouses', meaning warehouse district) in Hamburg, Germany is the largest warehouse district in the world where the buildings stand on timber-pile foundations, oak logs, in this particular case. It is located in the port of Hamburg—within the HafenCity quarter—and was built from 1883 to 1927.", Wikipedia.
Taken over county Mayo with the X-Pro 1
