Fuji Flowers
dv.
Locinera, shot with X-T10 and XC16-50mm OIS II, f11,1/200, at 16mm, slightly cropped
Regards Rieke
XF56 1.2 f1.2 ooc Astia
Liveimpression
https://500px.com/liveimpression
X-T1, Jupiter 9 (85mm f/2) wide open. Look ma, no noodling!   ;)
Regards Rieke
xe2 kit lens
60mm macro
First try with my new XF90mm/2.0.
It's an incredible lens :-))
X-T1 + XF90mm/2.0
X-T1 and XF16-55mm/2.8
Just tried my new Lensbaby Fisheye on my Fuji x-t1 yesterday. Its a fun lens to use and certainly engages the brain to try and find images that work! Loving it though!
Rosie
X-T1 and Zeiss Touit 50mm / 2.8 Macro
...XC 50-230
Liveimpression
Tiny Rucola blossom - X-T10 with XF27mm, f 2.8, 1/125
Regards Rieke
