Fuji Flowers
dv.
[/url]_DSF1419 by rafael.kamaltdinov, on Flickr">http://26793731404_a9fcaa63d6_k.jpg_DSF1419 by rafael.kamaltdinov, on Flickr
[/url]
>_DSF1412 by rafael.kamaltdinov, on Flickr">http://26793720734_8f35aea858_k.jpg_DSF1412 by rafael.kamaltdinov, on Flickr
Good  day
Fuji XE-1 with 18-55
This flower came from the plant called "Esclepiades."
Regards
Hello
A Hibiscus
Regards
Another hibiscus
Fuji XE-1 18-55
Regards
[/url]_DSF1770 by rafael.kamaltdinov, on Flickr">http://26850892003_9011356471_k.jpg_DSF1770 by rafael.kamaltdinov, on Flickr
[/url]
>_DSF1765 by rafael.kamaltdinov, on Flickr">http://27386617361_f6cac90e50_k.jpg_DSF1765 by rafael.kamaltdinov, on Flickr
[/url] >_DSF1762 by rafael.kamaltdinov, on Flickr">http://27423747346_c580606f32_k.jpg_DSF1762 by rafael.kamaltdinov, on Flickr
Flower admirer
XT1+50-140 mm lens, JPEG original
flowers
Edited by Fernandohk
XE2 with X90
Pinky Lotus
XE2 with 35mm f2
    • I have an X-T5 and am having the same problems with write errors in both SD slots. I'm using Lexar Pro cards that have been formatted for the camera. Any suggestions other than sending it back (at great expense) to Fuji Canada?
    • Some elements in (autofocus) lenses are „floating“, so I guess what you are experiencing is normal.
    • How do I turn off the electronic shutter in the menu - the option is grayed out and I cannot select the mechanical option
    • I'm having trouble finding a way to attach a right-angle viewfinder to the Fuji X-H1 camera. Does anyone have experience with how the angle viewfinder behaves in combination with the EVF? Is the Minolta frame diameter of the right angle viewfinder suitable for attaching to the Fuji XH1 (or XT1, 2, 3, 5)? Does anyone have knowledge about which eyepiece is compatible with the Fuji X system? Thank you in advance for any assistance and information you can provide.
    • I purchased a gently used XF 80mm f/2.8 aspherical macro for my X-T5. Not being familiar with this lens but having had experience with the Leica T mount 60mm macro and Canon and Zeiss macros, I was surprised that I felt what might be best described as a loose lens element that shifted when I tilted the lens, even before being mounted to the camera. In manual focus mode, the lens is fine, but there is a distinct “wobble” when the lens is in autofocus mode. I reported this to the company (I bought it from KEH), and they agreed this was odd and accepted it back for a full refund. I just got a replacement lens and the same thing is happening. I’ve never had an experience in which I feel a lens element loose inside the housing. Is this normal? Should I return it (again)?
