Which 3 primes combo is your ideal setup?
xherion
16, 23 and 56. It's the perfect to-go choice for me.
This was the setup I just used for two weeks in the south of Spain.  I would say that the 23 was used about 75% of the time with the other two being about even.  I love the 56 but may give the new 90 a try when it's released.  By the way, the 16 has become my normal street lens replacing the 18. It's much bigger but damm is it sharp !!!
hmm, of the lenses I actually own a two lens set is easy --23 and 60. For three, I would have problems choosing between the 23 and 35 to add to the 14 and 60.
If I were allowed to choose primes from scratch and zooms didn't exist in the system then 14, 35 and 90 would be the most useful. Travel light then 14,27 and 60.
Just got the 16mm 1.4 after i sold my 14mm 2.8 a few month ago. The 16mm 1.4 is definitely one of the gretest lenses in Fuji's XF line, and is surprisingly versitile. So i would have to put the 16mm 1.4 for wide nature and astro, 27mm 2.8 for candid general and walk around, and the masterful 56 1.2 for sheering sharpness and bokeh.
I don't really see how it makes sense to take a 90 over a 56 when you're restricted to 3 lenses only, it's surely not as versatile?
I see the most versatile packs as :
Cheap, compact and light : 18 - 27 - 35 (35 can make great portraits tbh and is very versatile)
High end, more heavy / bulky : 16 - 23 - 56
90 - because I can't always get close enough.
Sure but you can't always step back enough either. If you don't have enough reach with a 56 you likely won't with a 90 either. Or that will be too much. Either way you're screwed if you can't move.
And you lose the ability to have a "normal" compression for portraits, with a 90 you're just crushing everything.
Really to me the 90 is a fourth lens to have, not a third one.
Maybe it's just that it's new so people are excited but will change their mind in 6 months as usual.
16 - capturing nature, also in low light and with rough weather conditions
35 - my allround lens. Sharp, fast, lightweight.
56 - crystall clear, sharp images, people photography, wonderfull bokeh. I am sure the 90 is an amazing lens but I prefer to do some "footwork" to get closer and get in contact and in a relation with my subject
An interesting question for me b/c I recently switched from mainly using the 18-55 to using primes most of the time (although I think the 18-55 is still great when going out with only one lens, because the IS is so good.
Mostly I'm using 14, 35, and 56.  But I do have the 23 and feel like I should use it more. The 35 is great but I find the autofocusing a little slow at times... the 23 may be a little better in that respect. I really like the 35 (50mm equivalent) perspective though.
Bob
I really like the compactness of my 18.  I would like to get the 56.  My XT-1 came w/ the 18-135.  So currently  I count on my trusty x100s for its 35 "prime" and I bought the 50 for it.
Seems like most of you are going to get the new 16mm.
Is it really that good?
You guys are killing me, thought i would do ok with 14/35/56, but now i am really contemplating to switch the 14 with 16mm.
Anybody has size comparison between 14 / 16 mm? In picture i mean, not dimensional numbers.
    • So I ended up getting and X-H2 over the X-T5 because of a good deal that came up.  Needing to buy a card, I needed to figure out,  what is the real impact of a card's speed for photos?   In particular, I'm going to test how shooting at 15 FPS will differ between: Angelbird - AV PRO CFexpress B SE - 512 GB and Angelbird AV PRO CFexpress SX - 160 GB. How many shots can I get off before buffer fills, and how long does it take for the buffer to clear?    MOP: X-H2 Factory rest, card formated, no lens (body cap on), performance boost on, manual exposure, mechanical SS @ 1/8000, IS off, Shoting RAW Compressed Lossless with only one card in. Held shutter release till buffer filled, and used stop watch to see how long for buffer to clear. Subtracted two frames from total taken as that's how long it takes me to release the trigger once the buffer is full. Repeat 2x for sanity check.   ***TEST RESULTS***   ~~~64GB Lexar Pro SD 150MB/s~~~ 75 shots to fill buffer, 36 Seconds to clear it   ~~~Angelbird AV Pro SX 160GB~~~ 251 shots to fill buffer, 5 Seconds to clear it   .~~~Angelbird AV Pro SE 512GB~~~ 232 shots to fill buffer, 4 Seconds to clear it     ***Conculsion***   If burst shooting an X-H2 at 15 FPS is your thing, buy the Anglebird 512GB SE for the same price as the 160GB SX.   Below is a shot on X-T2 w/ the Fuji 70-300. I manged to fluke it off with a dead battery by turning the camera off and on again, and squeezing three more shots out (this was the last shot).   Ta for now!
    • Xt5 firmware updated and now cannot see pics taken on lcd when pressing playback. Any ideas please? Elie
    • Have you tried a factory reset? Maybe you changed unintentionally a setting?
    • Hello. I have a x-s10 that I use multiple lenses with. Yesterday I noticed that with the Fujinon 16mm lens I'm having issues auto-focusing. It works on video but not for still images. When I half press the button it focuses a bit then when I release the button it snaps back to the previous focus point. Even though it manages to focus the image is still blurry. Any ideas please. I already did a a major google search and nobody has mentioned this issue. Thanks, Etienne
