New to Fuji cameras.
16 hours ago, Steve533 said:
My name is Steve S.I live in the Denver area, and i'm a retired Navy. I know a bit about photography but not nearly enough to justify buying a GFX-100s.
I optimistic I can learn enough to figure out what this camera can do. Thanks in advance!
that's a very good camera . if you like to take pictures then your choice is totally justified ! wish you good luck with it !!.
Hi Steve, it might be a good idea to rent or try one for a couple of days and use it just like you'd use any other camera. The GFX platform is great, but not for everybody's needs.
