For my taste, the bokeh wide open is excessive, resulting in rather artificial / surreal-like images. When stopping down it does sharpen up, but at that point I prefer using the Leica 50mm f1.4 Summilux ASPH.
I hope you aren't forgetting that a f/1.4 on a FF sensor renders roughly the same out of focus blur as an f/1.0 on an APS-C sensor. That is one of the reasons why I like the really fast Fuji glass.
From a rendering perspetive you can compare the XF23 and XF35 f/1.4 with Summicron 35 and 50 lenses. Not with Summilux lenses. From an exposure perspective on the other hand they are Summilux speed.
That's the downside (and sometimes upside) of a smaller sensor: a deeper depth of field. For me it is mostly advantageous as I find f/1.0 or f/1.2 or even some f/1.4, depending on the focal length, nearly impossible to focus properly at shorter distances – typical people shots in low light. There I appreciate the lens speed while enabling me to focus a little bit easier.
Personally, I'd love an XF35 f/1.0 lens as long as the quality wide open is more Summilux than Noctilux.
I've said it before, but I'd still drop everything and save for a ~33mm f/1.0. I love the 35mm but it's a little tight for me for every day use, so it's more of a specialized portrait lens for me, and I wouldn't mind dealing with the size.
Another lens I realized I'd really like to see is an XC ~10-16mm zoom. I've almost rounded out my kit, and just need something legitimately wide (my widest lens is the 18mm right now). I'd love the versatility of the 10-24mm, but since my jobs are primarily events and portraits, the speed of the 16mm is probably more valuable. But if they made a cheaper XC ultra wide zoom for $300 or so, I'd definitely pick it up for when I want to do really wide landscapes and dance floor photos.
I'd love to see a 10-24mm WR. Other specs could stay the same. I'd also like to see a 55-200mm WR with improved autofocus. Those two lenses plus one of the 35mm versions would be my ultimate travel kit. The 50-140mm is an amazing lens, but I want more reach than aperture. I have the 16mm and the 10-24mm and although the image quality is higher on the 16mm, I would take a WR 10-24mm any day for a travel kit. The missing pieces from 24-34 and 36-54 wouldn't really be a concern for me if I had this setup.
I currently have the 16mm 1.4 & 35mm 1.4
Wish list as follows:
90mm f2 (which I hope happens on the 15th of this month)
120mm f2.8 (maybe later in the year)
Maybe the 56mm 1.2.  I need to see if I'll need it after I purchase the 90mm, maybe I'll rent it first.
I want:
 56mm 1.2
I have:
XF10-24 F4 R OIS
XF27mm F2.8
XF18-55mm F2.8-4 R LM OIS
XF60mm F2.4 R
F18-135mm F3.5-5.6 R R LM OIS WR
XF55-200mm F3.5-4.8 R LM OIS
Leitz Wetzlar Elmarit R 90mm F2.8 - Fotodiox LR-FX
Leitz Wetzlar Elmarit 135mm F2.8
Carl Zeiss 32mm 2.8
You already have the 56mm field of view, or close to it, four times - in three of your zooms and the 60mm. Is a fifth version overkill?
Yeah, and the versions he has are pretty simialar. f/3.5, f/4.0, f/4.x (in the 18-135) and f/2.4. f/1.2 sounds like a useful variety if one is into portraits.
I'm curious - how many people out there would like to see PROPER manual lenses in the X-range?
Imagine the 56mm, 35/1.4, and a host of other fast primes, fully manual (not focus-by-wire), weather-sealed (or not), made by Fuji and costing half or a third as much.
That would definitely get me buying Fuji X-glass. As it stands, I am a film convert and really prefer to shoot tactile legacy glass, but if Fuji's lenses were actually proper manual and built specifically for the system, well, that'd be tha shiznit.
Anyone else have similar thoughts?
@TaffyTheGog
I think it is not really focus by wire that is wrong in general but Fuji could have implemented the operation a little bit smoother.
I also tend to rant about that many Fuji lenses do not have stops at the ends for the focus and aperture ring and other things. But this mostly comes into my mind when I am sitting at home, playing around with my Fuji gear and dreaming of all the wonderful pictures I could take if just Fuji would finally make the right equipment for me.
However when I am actually out and shooting I normally do not really miss these things. Instead, I find that I get more and more used to my equipment. Things that started as a work around become normal and convenient. I believe it was Zack Arias who said: "It's the moron behind the lens that makes the picture."
Regarding the price I think, that today, normally, it is more expensive to manufacture high quality mechanical parts than electronic parts. So I do not think that a full manual focus lens can be manufactured significantly cheaper than then AF lenses.
The lineup is quite complete as it is.  The only lens I'm actually  waiting for the 33/1.0.  I think it would be wise to do version II of the original primes, especially the 18 and 60.   The 60 would be great with the same optics but faster focus and possibly OIS ..and a retractable hood. They could make a 200mm f/2 or a 300/2.8 but I would probably not buy em since the 100-400 is all I need.
