Jakarta street
Social housing recycling,London 2015 #x100t
Old Timers
Victoria, Gozo, Malta, 2015
On Flickr go to your photostream. Click on the photo you want to post. That will open the photopage for that image. Click on the share icon (on the lower right, it's the third of a group of four and looks like an arrow pointing right). On the box that pops up  select BB Code and select the size you want to post from the drop down list. Then copy the link and paste it straight into the reply box on the forum. If you want to make sure it has worked you can click on the 'More Reply Options' on the bottom right and hit 'Preview Post'.
Hope this helps.
Hope this helps.
Thanks a lot Olli!
    • (Open Thread) Not a winter landscape, but still cold.
    • agreed on the upload but based on the location and number it sounds exactly like the storage slot 1 status icon
