Hi, I was wondering if anyone who has been lucky enough to already receive their X-T2 has also encountered this error? About 9-14 seconds into video recording, the camera saves the video, and "Write Error" appears on the screen. I have tried using each of the film simulations, different memory cards (each formatted by the camera beforehand), different lenses. I can't seem to isolate the problem based on some external factor, so I'm thinking it's firmware/camera related. The videos the camera saves are intact and viewable, just short.
Any help would be greatly appreciated. Thanks!
I shot approx 40 min of footage (in total) yesterday at my first XT2 wedding.  Video was flawless.  Still shot a bit of vid with XT1, but favoured the XT2 for most of the video work.
The cards I use are Sandisk 80mb/s and Sandisk 95mb/s.  All video was 1080p 30fps.  At home I played a little with 4K but didn't shoot more than a 20 second piece.  That worked OK as well.
You can direct video to either SD slot 1 or 2.  Try a different slot or maybe a faster card.  If all fails, I'd return the camera.
What's the speed of the memory cards you're using?
I've had good results with Sandisk U3 90mb/s. This is the read speed though, the writing speed is lower.
I've had your problem in the past with another 4K capable camera. I thought i had a fast SD card, but the write speed wasn't fast enough. Most of the time it was ok, but when there was a lot of image fidelity the camera gave me an error. After I switched to a more reliable SD card, I haven't had the error anymore.
Ya, we need to watch the speeds posted on SD cards as it it typically the READ speed they post, no the WRITE speed.  So you may purchase a card that says it is 80mb/s but in fact that is READ when the WRITE may be 40mb/s.
I use the Sandisk 95mb/s READ which has a 90mb/s WRITE ... they cost a little more but prevent any issues.
  • 8 months later...
Had the exact same issue with my X-T20 and SANDISK 64GB ULTRA PLUS (90mb write speed, microSD card with adapter) card.
So 4K recording was working good, until some time, then the problem begun and after 9 seconds after start it was giving "write error".
SOLUTION
I simply removed the card, put it back.
Removed the battery and immediately turned on the camera (yes without battery).
Then turn off the camera. Put back the battery and card, and voila! It is working again.
Hope this solution will work for you (just registered to write this).
Edited by SirusVirus
  • 1 year later...
Hi, Im currently experiencing a problem with my 14 month old Fuji XT2 video recording function. The stills function works fine. About a week ago I tried to use the video recording and found after about 9 secs the camera stopped recording and shows Read error, when I try to view the short recording it shows Read error. Have used 23 and 64gb Sandisk Extreme pro cards which have in the past been OK with video. I contacted the Fuji UK support team and it appears it maybe a fault with the camera internal card reader. Im disappointed to say it may cost me for the repair unless anyone on this Forum can suggest a possible solution. Thanks for reading my post. regards  James
Hi, I had exactly the same problem with my XT2, using 64Gb Lexar 2000x UHS-II and Sandisk Extreme Pro 64Gb a couple of days ago (XT2 firmware 4.10). I very rarely shoot video, so don't know when the issue began. I was trying to shoot 1080 @ 29.97P and had the error on four different cards (two each of the above). However when I changed the frame rate to 25fps it worked flawlessly. I Have just tested it at 50P - it worked flawlessly - and again at 29.97P and ironically it is now working without issue. I wonder whether it hd something to do with the latest firmware update (I went from 4.0 to 4.10 without the intermediate roll back) and simply needed the settings altered!?! I wasn't using the battery grip at any point and the battery hasn't been removed or recharged between episodes.
Hope you get yours sorted without recourse to the repair shop.
Just ran into the same problem of video locking up after about 9. Seconds tried a few things but what worked was doing what PhilS suggested. I was on 4K 29.97 switched downed to 25 sho a video then switched back to 29.97 and still working fine. Go figure lol
also have the sticking shutter button so I think I need to buy the X-T3 then send in the X-T2 for repair and keep it for a back up.
  • 4 months later...
Hi,
I had the same writing error (on the X-T3), and I figured it was due to my memory card's speed : too low. I fixed the problem by downgrading the speed writing to 50mb/s, but I'll buy a faster card in order to get the full potential of the camera.
Hope it helped !
  • 7 months later...
  • 1 year later...
just had this is issue happen on a wedding :( luckily key events captured on my slower 80MB/s 64GB cards decided to use 2 brand new 120MB/s 64GB cards formatted in camera and in Dual slots in my XT3 filming 4K 24 FPS / 60FPS. when I switched back to the slower cards. no more issue. hopefully someone with more knowledge can explain why the card write speed maybe the issue?
using Transcend U1 10s btw
  • 1 year later...
30 minutes ago, cpX said:
I quote:
*3 Use cards with a video speed class of V60 or better to record movies at a bit rate of 400 Mbps. To record movies with lower bit rates, use cards with a UHS speed class of 3 or better or a video speed class of V30 or better.
So V10 is not really suitable...
The V10 speed class guarantees a continuous rate of 80 Mbits/second which is only fast enough for the lowest resolution video - sometimes the cards are conservatively rated and might be a little faster in practice but its much better to get at least a V30 card (and these cards are relatively inexpensive these days)
    • Sorry for bumping this thread but I am having the same issue. However, for the first few days I used the lens I had no issues with the 50R recognising the aperture on the same Mitakon lens. It just then suddenly stopped. Not sure if this is an error with the camera or the lens. I did a factory reset of all the camera settings but that didn't change anything unfortunately.  Did anyone manage to resolve this?
    • Hello guys, i just got my new Fuji xs20 and im a bit disappointed.  I bought it mainly for the auto scene modes as Sport/Portraits etc and the good focus System.  Playing with it yesterday i just realized that when using the scene modes you are forced to use those useless filters on top of the film simulations and also the option for susbject detection focus or eye detections are not usable, they are grayed out. here to ask if im missing something? there is a way to remove the filters and activate the focus detection mode or is this camera a joke? 😂   thanks
    • I really like the image quality, size, and weight of my mark II. I never owned the mark I so I can’t help with comparison though it is highly regarded as a great lens.  I don’t use mine for video but I will say it doesn’t have the smoothest zoom, which seems to be common complaint for the mark II.  For photos it doesn’t bother me but I would imagine would be an issue if zooming while recording video.
    • Good day fellow Fuji people   I wanted to ask your opinion on the subject of the 16-55mm Mark I vs Mark II. I want to use it mainly for my concert photography where I currently use my 50-140mm and a second camera with a prime lense. I would like to use a second good quality zoom lens thats why I became interested in the 16-55mm. My question is for anyone having experience with both wether the new one (which looks very promising but pricey) or the older one (much heavier but seems to deliver on optical quality and I could get that used for roughly half the price of the new one)?  From what I could find online I guess in terms of pure image quality both are going to deliver. So then it would come down to usability, ease of use, maybe video ability, and longevity etc.  I use my Fuji X-H2 and Fuji X-S20 currently. If anyone has thoughts I would be highly appreciative. Thank you in advance,   Best regards from Switzerland, Mischa
    • It'd be a bit of a rigmarole, but maybe enable the function buttons on the lens, focus on infinity (distant tower/tree/mountain/etc), then set that as a focus preset. Use a function button to return to that infinity focus when you have a bird against a clear sky. I have the same problem with my XF 150-600, so far I just put up with it, or zoom out enough to find and focus on the bird, or focus on a distant treetop etc.
