When did the problem start, and how did you transfer the file—direct connection, cloud, or another method?
Thanks, but none of the options quite do what I want. EVF only + sensor displays the taken image on the EVF screen not the main screen. EYE SENSOR + LCD IMAGE DISP. keeps the screen turned on unless I'm looking through the viewfinder.
The user manual explains how to configure image review on the LCD screen. https://fujifilm-dsc.com/en/manual/x-t5/menu_setup/screen_set-up/#image_disp
Hello, I moved from Canon to Fuji and I'm impressed by what a difference it makes. I have one question though. In canon (5d ii), I was very used to a flow of 'take a photo through the view finder' - 'look at result on screen'. In Fuji, I can't seem to figure out a way to keep the screen off (to conserve battery) for 'live mode', but still have the results display there once the photo is taken. Any way to set it up that way? Thanks
Jesse. I just joined. If you are still interested, I shoot sport and other stuff with two xhs2 bodies. They’re a good job. I have an xt5 which I use for non sport and I think it is good too. Too be honest, most cameras these days are great. If it is fast moving photography you’re into, it is more unforgiving. The xh2s’s are a good bet. I have wasted way too much money over the years selling good gear to buy newer gear so take it all with a pinch of salt!! If you can, try them out. If you can avoid the need for the stacked sensor, Fuji have some other marvellous options. Cheers, Sam.
