A view from a roadside stop:
Autumn is strolling on in.
Here is my attempt at capturing the colors of the fall. I didn't have any polarizer or grad filter so my sky got blown out
Hello to all,
My small contribution...
Fujifilm X-Pro3 & XF 80mm
Fujifilm X-Pro3 + XF 50-140mm
hello... my first photo posted on this forum ...
2019. Slovenia, Logarska dolina, beech forest
Fujifilm X-T20+XC16-50mmF3.5-5.6 OIS II; 16mm; f5; 1/25; ISO320; tripod
vertical II
Fujifilm X-Pro3 + XF 80mm Macro
Fujifilm X100V - Wide Open @ f/2 - Classic Negative Color Film Sim
Autumn Storm's a Coming
2019. Slovenia, Logarska dolina, beech forest ...
Welcome, greetings from Slovakia. Beautiful pics on your flickr ! Slovenia is a beautiful country. I climbed Vrsic by bike a few years ago, would love to do Log pod Mandartom sometimes. Bled is beautiful, the valley of Radovna... Post some more !
The Cabin In The Woods
Fujifilm X-T3 + Laowa CF 9mm F/2.8 Zero-D Manual Lens
The Roman Bridge in Glen Lyon, Scotland last autumn
Another from Glen Lyon last year
X-T1 | Rokinon 12mm f/2
Edited by JXPhotoGuy
