Somehow I have a small scratch right in the middle of the rear LCD on my X-T2.  Looking to see if there is a simple, easy solution for how to remove it.  It is not deep.  I put a glass protector on it (too late) thinking that might cover, but it makes it more apparent.
Looking for good reliable suggestions which will not further damage the LCD.
Thanks
if it is glass a plastic cleaner wouldn’t do anything to it.
Glass is harder than plastic.
Only very strong acids can etch glass and a product made to be used on a car lacquer to take away scratches is, of course, safe to be spilling on glass since cars have plenty of glass parts adjacent to metal ones.
Thanks
Get used to it.
Toothpaste is often recommended for cleaning scratches off mobile phone screens. (Just normal toothpaste, not one that's full of coarse abrasive grit.) You could try it first on another piece of glass to make sure it's safe.
these days there are some types of toothpaste which are absolutely useless for this purpose, they are the ones which contain enamel protecting agents.
Because I am a diver I know that  toothpaste is recommended to remove the protective silicone layer on the glass of diving masks and also all diving shops will tell you that some toothpaste will be useless for this purpose.
Anyway, the right toothpaste (traditional old fashioned one) will help but it will take a long more time that auto lacquer cleaner.
I use CREST toothpaste on my Tag Heuer watches.   WORKS AMAZINGLY well.  I haven't tried it on a glass screen tho.... I'd test it on an old piece of glass.  I've also used jewelers roush to deep polish automobile glass and that works amazingly well to.
Get used to it. Trying these diffferent "recipes" will probably remove the scratches but also the anti-reflective coating of your screen.
What is "Jeweler's Roush"?
It's a type of polish.  I use the "pink" formula on automobiles.  Jewelers also use it to clean jewelry, and crowns.  Google J Kolinsky.  He makes my auto polish and he sells various grades of polish (not wax).  One is fine as jewelers rush
Been using this polish for over 10 years and still no detrimental effect. However, I will agree that ANY type of polish is an abrasive and will remove fine layers of coatings, and/or paint. That's how you get the smoothness and shine on an automobile.  Polish, and wax.
I would suggest not doing anything to it that could potentially invalidate your warranty on surrounding parts if they become affected by the "cure". If you just can't live with the scratch, I'd contact Fuji service and find out the cost of replacing the screen. It's not a cheap camera and if you plan to keep it for several years, you will probably be happier for having done so.
    • I never knew the X70 existed! Looks interesting.
    • Equipment: Fujiflim X-M5 (firmware V 1.10). iPhone 15 pro (26.1) I am unable to properly connect my Fujifilm X-M5 to XApp on my iPhone 15 Pro. This setup previously worked without issues, but now the app only supports a basic remote shutter and no longer allows Get or Take mode, which are required for remote parameter control and shooting. I have repeatedly Initialized “FUJIFILM XApp”, re-paired the camera, reset wireless settings, and confirmed the camera is not in airplane mode, with both devices placed next to each other. None of these steps resolved the issue. Also, I am unable to update the camera firmware, as the process always fails with a “connection failed” message. I need clarification on whether this is a known firmware or compatibility issue and what the actual solution is.
    • Last day of autumn 2025. Autumn is gradual. Summer field crops slowly ripening. Cool, longer nights turn into morning fogs. Color (colour) touches here and there taking the place of flowers now resting until Spring. Then, after that slow introduction, Fall is everywhere. Winter is brash, Winter is not at all subtle. Freezing cold days and colder nights. The Sun struggles to get above the horizon. Bare fields, iced over streams and woe (‘Woe!! I say!’) to trees or shrubs holding onto leaves.
        But there is sledding, skiing and hot chocolate for those that like those things 😀.
      Winter is coming.
    • For some reason, the EV dial setting does not correlate to the EV setting displayed in the viewfinder.  My XT2 used to have parity between settings such that when the dial was at "0", the viewfinder also showed "0".  Has anybody else noticed this?  I've tried a reset of the s/w but no luck.
