You can post now and register later.
If you have an account, sign in now to post with your account.
I have the EFX eight flash and my XT4 is reading it as down instead of up and when I put the flush down, it thinks it’s up. I’ve already reset the settings have purchased a new identical flash and still doesn’t work.
All lenses are a compromise where the designer has to decide what is most important to correct. Most modern lenses, particularly zooms, rely on software to reduce some faults. This allows the lens designers more leeway to address other problems. Vignetting is usually on the list. It will be corrected in the camera in the case of jpegs or in the software in the case of raw output. If you use raw check that automatic lens correction is enabled.
