T2 advantages over X-Pro2
bitbonk
Now that the X-T2 is out, I would like to compile a comprehensive list of advantages the X-T2 has over the X-Pro2. Can you help?
Starting with the viewfiner: it is brighter and larger (how much larger?) and has a higher framerate (100fps instead of 70fps), right?
I think one of main advantages is the AF improvement, mainly about AF-C settings.
But let's wait for next X-Pro2 firmware update (2.0) coming in October that promises AF improvements.
AF improvements in general will be transferred to the X-Pro 2.
But the AF-C settings are X-T2 exclusive.
It has a 0.77 magnification compared to 0.59x with the X-Pro2
More advantages:
- 4k Video
- USB 3.0 transferring 480MB/s
And of course different ergonomics...
Andreas
Off the top of my head:
4K
F-Log (via HDMI, also 4:2:2 via HDMI)
Headphone jack (in grip)
3.5mm mic jack
AF-C profiles
Bigger/Better EFV
Zebra
Peaking during video recording
Live audio monitoring that can be adjusted by assigned buttons
More AF points and more contrast detect AF points
Tilty sceen
Both slots are UHS-II type (only slot one is on the xpro 2)
Battery grip (xpro2 obviously doesn't have
11fps in boost mode and apparently it can go 14fps with some restrictions
I think the buffer is bigger
