Which Fuji X cameras do you use? Update 12-2018
873 members have voted
  1. 1. Which Fuji X cameras do you use?
    • Fuji X-H1
      113
    • Fuji X-T1
      139
    • Fuji X-T2
      258
    • Fuji X-T3
      211
    • Fuji X-T10
      37
    • Fuji X-T20
      91
    • Fuji X-T100
      20
    • Fuji X-Pro1
      68
    • Fuji X-Pro2
      128
    • Fuji X-E1
      55
    • Fuji X-E2 / E2s
      74
    • Fuji X-E3
      75
    • Fuji X-A1 / A2 / A3 / A5
      10
    • Fuji X-M1
      9
    • Fuji X100
      29
    • Fuji X100S
      35
    • Fuji X100T
      32
    • Fuji X100F
      103
    • Fuji X70
      20
    • Fuji X10 / X20 / X30
      35
    • Fuji XF10
      11
    • Fuji GFX 50S
      13
    • Fuji GFX 50R
      16
This poll is closed to new votes
  • 1 year later...
