Hello,
I am having some trouble with my ERF function on my XPRO 2. It really started after I implemented the 4.00 update so I'm wondering if that has caused it. Since then I have done the 4.01 update and the problem still persists.
After doing a lot of google searches (and forum searches) I found that most people this happened to solved it by setting the AF to "Single Point," so I did the same and the ERF still does NOT function.
Just to be clear the front switch DOES toggle between OVF and EVF with no problem, when I push the switch to the left (toward the lens) the ERF no longer does anything.
I tried to reset everything via the Menu and that did no help either.
Are there any other settings I should know about to get the ERF to pop up in the corner, or that would keep it from functioning? Or is there a way to factory reset (resetting firmware as well) utilizing more than the options in the menu?
Hope someone else out there can help!
Thanks,
Jacob
