Hi
From last weekend, taken at the Canada Cup Long Track Speed Skating competition in Québec City.
Close to one hundred of the best skaters in Canada were in town for a three day event, the first races in a series of four this season.
Shot with a X-T2 and the XF50-140mm with the XF1.4TC, AFC on zone (3x3 grid), on CH at 11 fps with the battery grip on boost.
I shot this event twice before, twice in 2015 with my T1..... and I got to say it,  I just love my T2   :D
PP in LR 6.7 and the Nik suite for all sharpening and Noise Reduction.
For those of you who would like to see more here is a link to the Flickr album: https://flic.kr/s/aHskHye7Vf
Thanks
Gilles
31564079896_1574c17d37_c.jpg[
Edited by GilBarib
It's many years ago that I have skated on natural ice ... I am jealous! ;)
Very nice pictures as well.
Thanks Johant !
It is natural ice for sure but there is a heavy duty cooling system build under the ice ring, I guess they could get it to freeze right in the middle of summer if it was not for the energy cost !
There is a project here in town to build a new covered long track ice ring, with all the modern confort, it should be great for the athletes and the spectators.....but not so sure for us the photographers, I like the natural light on the outdoor ring !
Gilles
Hi Gilles,
When you shoot at 11fps, how do you feel the AF performs?  Does it generally keep focus?
Thanks!  Nice set of images!
Kevin
Hi Kevin,
Thanks for the comment !
At 11fps the AFC did fine (above 90% in focus) as long as I kept the skater inside the 3x3 grid, I feel that the 11 fps on the T-2 + VPB grip (on boost) make it easier to follow a moving target through the EVF than the 8 fps on the T1.
I tried to keep the burst sequence as short as possible, usually from 4 to 6 frames, just  enough to get the full sequence of mouvement from the skaters.
I tried most of the AFC settings during this 3 days event and settled on the custom one, here's the value I used:
Tracking Sensitivity: 3
Speed Tracking Sensitivity: 1
Zone Area Switching: Front
Hope it helps !
Gilles
Here is an example with 3 pics, they are not consecutive but from the same long sequence of a total of 15 pics:
30853409813_d3492de9aa_b.jpgCC No1  #79 by Gilles Baribeau, on Flickr
30791440733_211055c5ed_b.jpgCC No1  #34 by Gilles Baribeau, on Flickr
30791434523_54ee2f21d0_b.jpgCC No1  #32 by Gilles Baribeau, on Flickr
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
