XF 16-80 not holding focus at long end of the zoom range
My XS-10 is just under 5 years old, and I use it extensively as my webcam through an elgato capture card. A few days ago, I started getting some disturbing glitches where the color and focus would degrade, and there was pulsing and flashing on the camera screen, and on my Mac screen. I have tried to identify the problem: plugged in, and unplugged, updated the firmware, changed shooting modes, reset camera settings to factory, etc. Unfortunately, the issue keeps coming back. The only thing I can guess is that prolonged use as a webcam eventually cooked the board. Any ideas on the problem or the fix are most welcome! xs10 glitch.mov
Cedar Waxwing, Oregon. X-H2s, Fuji 150-600+1.4TC.
Have you checked the settings for jpeg? I found the camera was slow between shots. On the advice of others in this forum I turned 'clarity' tp zero and that makes it much faster. Other jpeg settings on that menu might also make it slow. Lens corrections for instance. I have them at zero because I shoot RAW. Paul
No, I was not joking. Reread her post, the first sentence is “The focus mode selector button on the front of the camera has me baffled.” which is what I explained in my answer: the focus mode selector button. My CSM explanation is essentially the standard approach Fujifilm has taken for some time. Explaining the frame rate differences as I did to someone brand new to the camera seems an easier approach to understanding than saying it is 20fps vs 7fps. Not to mention, the following is how Fujifilm describes it: “Continuous AF: Focus is continually adjusted to reflect changes in the distance to the subject while the shutter button is pressed halfway. Use for subjects that are in motion” https://fujifilm-dsc.com/en/manual/x-t5/taking_photo/autofocus/ You have to go to page 166 of the manual to get to a very brief explanation of CH vs CL without any context. High speed capture vs slower speed capture seems appropriate to explain so that someone that had been given the impression the top dials are needed for the csm button would realize how they work. I think it is better than saying put the csm button on S the top dial on CH and mash the shutter button — there is no example of when to use that or why. The X-T5 is a wonderful tool, but sometimes examples, humorous or otherwise, help new users understand it better when the manual does not help or when people tell new users to just leave it alone.
The burst speed of the shutter is set by the CL and CH control on top of the camera, it is unrelated to the focus mode setting on the S C M control. The focus speed is not related to the burst speed setting. You might have been joking, but your post adds confusion.
