Had my X-Pro1 for almost a month and only shot with PROVIA/STANDDARD which is fine and gives very neutral colors but it's kinda boring.
Tried the NEG.STD today and I have to say I really liking the result with less saturated colors. Looks a bit more clean to my eyes for some reason.
Which film simulations do you prefer using and in what situations?
I use ProNegStd profile a lot for RAWs because great headroom for postprocessing.
When jpegs only, I use Provia or Astia profiles, depends of scene and light. Portraits are better with Astia.
For night shots, ProNegHi works fine for me.
Never was lucky with Velvia - colors too fat, fine details mostly gone. Good for regular vacation shots though.
