I have the same issue. I included the steps I followed below.
1.
I customised the front dial to change aperture and set the lens to A.
I have the rear dial set to Shutter speed
Result:
Front dial won't change the aperature.
Rear dial will change shutter speed
2.
I then customise the front dial to change Shutter speed & Iso
I customised the back dial to change aperture
Result:
Front dial changes shutter speed, when I push the front dial in I can select the ISO, now the front dial changes the Iso
Rear dial won't change aperature
I tried this with two fuji lenses.
  • 1 year later...
Something such as this:
https://www.fringeradapter.com/canon-ef-to-fujifilm-x
https://fotodioxpro.com/products/ef-fx-fsn
or similar from one of their competitors might work for you.
Canon EF lenses all operate ‘by wire’, the body tells them how to set the auto-focus and f-stop, so you need an electronic adapter, otherwise they will work but shoot with the f-stop wide open.
p.s. Welcome to the forum.
Edited by jerryy
9 hours ago, Felipe Rodrigues said:
Yes, the adapter is manual and doesn’t include the electronic contacts. I knew I’d lose autofocus, but I thought it would be it. Manual focus can be handled, but losing aperture control is very limiting.
I went through this same problem some years ago with the X-T2 and bought the first version of the Fringer adapter that jerryy has suggested. It has worked very well - and given decent AF performance as well as controlling the aperture.
Thanks for the reply and for the welcome!
I’ve always been a Canon user, but now I’m migrating to Fuji, I didn’t want to lose my previous equipment, so the adapter is going to help a lot! Thanks for the tip also!
I have one Fuji lens (the 16-50mm kit lens), which is great, but if I can use the Canon lens as well, it helps a lot.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
