X-E2 4.0 Applies 16:9 Crop to RAW Files in LR
Hey guys,
after importing the first images to Lightroom (on a Mac running 10.11.2) after the update I noticed a weird behaviour: All RAW images are cropped to 16:9 after import. Changing the crop ratio to "Original" instead of "As Shot" fixes things.
It's a small annoyance as it can quickly be fixed for all images but still it is kind of stupid. Has anyone else had that problem? The only thing I could find about it was this post on DPR: http://www.dpreview.com/forums/thread/3966021
Hi Jano - I'm intyerested in your post
I've been following this forum for a year or so but have only just decided to post. I have 3 Fuji X cameras: XT-1, XE-2 and X30.
This cropping phenomenon concerns me. My standard workflow (all 3 cameras) is: shoot RAW, convert to DNG, import into Lightroom 5.7 (Windows) and process. So does this mean, if I update firmare in the X-E2 (to Version 4.0) and X-T1 (to Version 4.30), that all my imports will display as 16:9 crops? ... and, if so, would I need to "Develop" each individual image in Lightroom in order to correct it to standard 3:2? The only correction I can see is to use the "crop and straighten" tool and hit the "reset" button for that tool. Is this what you have done?
I can't seem to find anything to alter the crop ratio - unless it's called something different on a Mac version.
I've just tried an experiment with my X-E2 running FW 4.0, importing files into Lightroom CC 2015.4.  I deliberately shot RAW+JPEG so I could check the aspect ratio of each independently, and - as expected - everything is kosher 3:2.  I'd be interested to know whether the JPEGs produced in "16:9 mode" have the correct number of pixels.  In other words, are the JPEGs cropped or is the 16:9 aspect ratio simply the result of a rogue piece of metadata?
I know that I followed the recommended upgrade path: start at 1.0; factory reset after upgrade to 3.0; then upgrade to 4.0.  I'm wondering whether the aspect ratio problem might be related to missing out the factory reset or going straight from 1.0 to 4.0.  This might explain vestigial "state" creeping into the new settings.
Ian.
As it seems this is a pretty rare problem. And even if you happen to have it don't worry. You simply select all images after import in the grid view and in the "Quick Develop" module (right side) change the "Crop Ratio" to "Original". I'm pretty sure it's called that on Windows, too. No problem, just an annoyance.
Ian.
Thanks for the reply Ian. I didn't follow the recommended upgrade path. It would be kind of embarrassing if that actually led to problems imho.
Anyway, the JPEGs are completely normal, all 3:2 at full resolution. The RAW crop is independent of the selected crop: if I shoot the JPEG in 1:1 the JPEG will be that but the RAW will be cropped to 16:9 in LR. Seems to be something in the metadata.
I did some further experimentation: no other app that I tried applied any type of crop to the RAW (Iridient, RPP, Preview, Darktable, Pixelmator). Weirdly, Fast Raw Viewer (FRV) can't open the files at all since the FW update.
I uploaded one of my RAW files to Dropbox here. If anyone would care to open it in LR and see if the same thing happens I'd really appreciate it!
I opened your RAW file in LR 5.7 (Windows 10) and it displayed as16:9 crop. I also reset the ratio using your suggestion in the "Quick Develop" panel of the library module and all is fine - it now displays as 3:2.
So, it looks as though this is perfectly usable workaround ... but I guess we still don't know what causes it.
I think I'm going to have to bite the bullet and update my 2 cameras (X-E2 and X-T1) to the latest firmware. I'll let you know what happens.
My latest X-E2 revision is 4.00.
I guess you're not quite up to speed then ;-)
Must be a camera issue then. I guess I'll write to Fuji and see what they say. Though I'm not expecting much – haven't really gotten useful replies from Fuji Germany, only excuses.
Thanks fabumann! I just took three test shots, one for each metering mode, and indeed a crop was added to the shot with the average metering mode.
I guess the next question is, "Is this an issue with Firmware 4.0 adding wrong information to the EXIF average metering or an issue with the way Lightroom reads EXIF for firmware 4.0?". I can't say, I remember this being an issue prior to the update.
A lot of "fun" little changes in the latest LR update that will bite you if you have everything memorized as it is (was). Like moving "perspective corrections" from "Lens Corrections" to a new menu - "Transform." It's my job, and it will be for the near future, but at least I'm done with it at home.
    • So I ended up getting and X-H2 over the X-T5 because of a good deal that came up.  Needing to buy a card, I needed to figure out,  what is the real impact of a card's speed for photos?   In particular, I'm going to test how shooting at 15 FPS will differ between: Angelbird - AV PRO CFexpress B SE - 512 GB and Angelbird AV PRO CFexpress SX - 160 GB. How many shots can I get off before buffer fills, and how long does it take for the buffer to clear?    MOP: X-H2 Factory rest, card formated, no lens (body cap on), performance boost on, manual exposure, mechanical SS @ 1/8000, IS off, Shoting RAW Compressed Lossless with only one card in. Held shutter release till buffer filled, and used stop watch to see how long for buffer to clear. Subtracted two frames from total taken as that's how long it takes me to release the trigger once the buffer is full. Repeat 2x for sanity check.   ***TEST RESULTS***   ~~~64GB Lexar Pro SD 150MB/s~~~ 75 shots to fill buffer, 36 Seconds to clear it   ~~~Angelbird AV Pro SX 160GB~~~ 251 shots to fill buffer, 5 Seconds to clear it   .~~~Angelbird AV Pro SE 512GB~~~ 232 shots to fill buffer, 4 Seconds to clear it     ***Conculsion***   If burst shooting an X-H2 at 15 FPS is your thing, buy the Anglebird 512GB SE for the same price as the 160GB SX.   Below is a shot on X-T2 w/ the Fuji 70-300. I manged to fluke it off with a dead battery by turning the camera off and on again, and squeezing three more shots out (this was the last shot).   Ta for now!
    • Xt5 firmware updated and now cannot see pics taken on lcd when pressing playback. Any ideas please? Elie
    • Have you tried a factory reset? Maybe you changed unintentionally a setting?
    • Hello. I have a x-s10 that I use multiple lenses with. Yesterday I noticed that with the Fujinon 16mm lens I'm having issues auto-focusing. It works on video but not for still images. When I half press the button it focuses a bit then when I release the button it snaps back to the previous focus point. Even though it manages to focus the image is still blurry. Any ideas please. I already did a a major google search and nobody has mentioned this issue. Thanks, Etienne
