Here are a couple of shots I took with the XF90mm f/2 lens the other day.
Just incredibly sharp even at f/2 - almost to sharp, and can be quite unflattering!
These are B&W JPEGS from the camera with only a minor touch up in PS to remove a coupe of stray hairs, otherwise they are effectively SOOC.
Lovely images. I have to get one of these lenses.
