By K PRETHVIRAJ
Hoping to see Fujifilm support shooting in HEIF / HEIC image format or introduce a ability to export in HEIF / HEIC image format in "Fujifilm x raw studio software" . canon has implemented shooting in HEIF / HEIC format with 1dx mark 3 , so even though they did it first , i hope to see Fujifilm implement it as soon as possible ,because of the advantages of that image format over jpg . it's not difficult to implement actually ,since it's the still version of HEVC ,same way jpg is like a still version of H.264 . the major advantage of using HEIF / HEIC format is the images has more bit depth ,jpg only has 8 bit color meanwhile HEIF / HEIC format can support up to 16 bit color which is like having the color range of RAW file . the next big advantage is the size ,a 10mb HEIF / HEIC file has better quality ,color depth ,details etc... also less artifacts , than a 20MB jpg file ,both jpg and HEIF exported from the same raw file . also if this image format is implemented in-camera like canon 1dx mark 3 , that means you can shoot twice the amount of picture with the same buffer size compared to jpg ( x pro-3 79 frames jpg only, xt-30 79 frames jpg only , xs-10 81 frames jpg only ) if the HEIF format is used (x pro-3 158 frames heic only , xt-30 158 frames heic only , xs-10 162 frames heic only ) with current buffer size itself we can capture twice the number of images at the max burst speed of the camera .also HEIF / HEIC format is actually better optimized for burst shooting mode ,so you will more likely get the max burst speed of a camera in all real world situations. so i hope that i mentioned the basic reason why we need Fujifilm to implement HEIF / HEIC format in-camera or at least in "Fujifilm x raw studio" as early as possible . please share this topic ,support , and send feedback to FUJIFILM to implement this image format in the Fujifilm devices and software's . i really hope that everyone will support this matter ,which will benefit everyone who uses Fujifilm devices , to a great extent . also if anyone is concerned about the compatibility of HEIF / HEIC formats (there is a lot of articles in internet saying there is compatibility issues or can't open in windows etc.. But that's actually past issues) . the current situation is it's fully compatible in windows starting with windows 10 ,it's natively supported in mac os and ios 11 and above , also natively supported in android , also you can edit HEIF / HEIC files in adobe software's , luminar , capture one etc. so i am hoping everyone who use Fujifilm devices , to follow up this matter till it's implemented , have a great day ahead !
By widespace
Hello
I bought a new Fuji X-T3 and went to take some pictures, JPG + RAF. I used two SIM cards (one as a backup). When I got back home, I started uploading all of them to my computer (Mac). I removed the main SIM card from the camera and plugged it into a multi/card reader, the same way I always do. There were in total: RAF = 147 photos, and JPG = 159 photos. I was able to upload: RAF = 75 photos (51%), and JPG = 117 photos (74%). After those photos were uploaded, an error message appeared in the screen: THE FINDER CAN’T COMPLETE THE OPERATION BECAUSE SOME DATA IN (NAME OF THE NEXT PICTURE) CAN’T BE READ OR WRITTEN. ERROR CODE -36. No more photos were uploaded, even when I tried several times. I also tried doing the process one photo at a time, and also repeated the process with the second SIM card. Same results.
Thinking that the two SIM cards were corrupted or damaged at the same time (???), I then tried to format and take some more pictures with another SIM card and to upload them to the computer. The same situation and exact message came up over. I am able to see all the pictures (RAF & JPG) directly from the SIM cards connected to the Mac, I just can’t upload them to it. My frustration is that 51% of the RAF, and 74% of the JPG photos were already uploaded using the same method, devices, computer, etc., without any problem, and then just stopped.
What can I do or check for? Is that something to do with the way the camera store the photos in the SIM card? Again, it performed as expected PARTIALLY, and then stopped!
Thank you for your advise.
This is indeed an issue that occurs more frequently with X-mount and esp. combined with the larger/heavier lenses. We've had it several times on various X-Ts and only the X-H1 is really better (and the GFX). Make sure that when they tighten the screws they put a drop of Loctite on the tip of the screw. That really helps.
Sports Finder crops the display by 1.25x, "reducing the picture by an amount equivalent to increasing lens focal length by 1.25x" ... says the user manual. I assume this means the 23mm lens effectively becomes 34.5mm (in full frame 35mm format). The Digital Tele-Converter on the other hand gives an equivalent to either 50mm or 70mm. Is Sports Finder therefore just another digital tele-converter, or is it doing something else entirely?
By InResponse · Posted
I now know the reason for the "shake" the mounting plate on the back of the camera is a little loose. I will return it to the shop and give them the option to tighten the screws as I don't have the apropriate tools. -
By Klaus Armitter · Posted
Purchase I ordered my lens from the Pergear because it has discount when I bought it. And I use it most the time with my X-T4. AF The aperture can be adjusted by turning the aperture knob at the bottom of the lens to A. You can use your favorite aperture adjustment method according to your preference. Build quality Build quality is really good. The lens hood is made from metal. It's small and lightweight. Love my new lens. https://pergear.co.jp/products/viltrox-56mm-f1-4-stm-大口径-単焦点レンズ-fujifilm-xマウント-オートフォーカス-ポートレートレンズ
