Flashing Display - Lens Error
It does look strange…, but no, it is part of CSX’s (a railway company) maintenance equipment.
By ruralrelic · Posted
Example: I am using a custom recipe, and I then use the film simulation dial to select a simulation. Are values from the custom recipe carried over, such as highlights, shadow, and white balance etc.? After studying the articles in Fuji X Weekly, this appears to be the case If you set a recipe on one of the C slots its settings will be applied to all the film simulations on the dial. The workaround is to use your 'standard' recipe at C1. Please clarify this for me . I would have thought the film simulation dial would have no input from other camera settings. Thank you - Very Confuded! -
Is this on the X-T30 II? Sounds like you have HDR selected in the shooting menu. The other alternative when you see the "storing" message is that the Clarity setting is non-zero but that doesn't cause multiple clicks.
My XS10 came with a Capture One license but my PC at the time would barely run it so I stuck with my ancient version of Picasa. Bought a new PC and my old Capture One has been deprecated and fuji site only talks about a 3 month trial. Is there a work around or should I be looking for something else?
