I'm on Adobe CC Photography program (photoshop+lightroom $10/month) and they came out with an update just before I received my pre-ordered X-T10.
It sucks how Adobe holds you hostage when you buy a new camera, forcing you to make a big upgrade just to get camera support when they could so clearly backport the camera support only if they wanted to. IMHO it's a reason to just bite the bullet and get the CC plan because that way you don't have to think about it, but it's also pretty expensive.
At the same time most of the competitive options are just as expensive. You pay $10/month for Capture 1 too, but that doesn't come with Photoshop!
You could always try Darktable, the open source equivalent, though I haven't used it and YMMV:
http://www.darktable.org/
  • 2 years later...
I am using the CC Lightrooom, and only signed up to it a couple of days ago, but absolutely cannot get it to recognise my RAF files. It sounds from some of the replies above that this should not be a problem for me as I imagine what I am using is the very latest version of Lightroom. I'm also finding it very hard to find any way of contacting Adobe.
Does anyone know how to solve this please?
BP
Just use the Free(!!!) Adobe DNG convertor. Google is your friend.
Convert the RAW files to DNG and off you go.
My T2 isn't recognised by LR5 so this is what I do. Adds an extra step in the processing but isn't too onerous or time consuming.
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
