I've been using my XH1 for a couple of weeks and have been shooting video. Recently when I shoot in F-Log I cant get the ISO below 800, it will let me choose a higher ISO but when I drop to 800 the ISO turns yellow and wont let me choose a lower setting. Am I being daft or have I clicked an auto setting by mistake I don't know about ? Any help or advise would be great.
  • 4 months later...
  • 5 weeks later...
  • 4 months later...
ISO 800 is expected for F-Log, same on the X-T3.
It's a reason why F-Log is not so great if you don't need the extra Dynamic Range. You get more noise, but also you can lose some midrange information.
Use F-log only if you won't be using the Eterna LUT and will do your own grade + You really need the maximum dynamic range because you can't control your lighting + You don't mind being at ISO 800 as you would need it anyway (semi-dark environment)
If you use Eterna in the end there is little point to using F-log, you're just adding an extra step to the process and shooting at ISO800 when you could be shooting at ISO200.
