Hi, Is someone know if I can get near 1:1 reproduction ratio using the two Fuji extension tubes with my 56mm? I'am looking for a set-up for digitalizing my B&W negatives. After trying few scanners in the under 1000$ range, I know I can do better using one of my Fuji cameras. I already get amazing results but looking to use most of the xpro2 sensor instead of around 2000x3000px area. As I already have the 56 and the 16mm extension tube, buying the 11mm tube will be much cheaper than buying the 60 or even the 80 macro lens... Thanks
So I assume nobody here know the answer...I ordered the 11mm tube. We will see. But I got another problem : grid artifact! Photographing negatives implies a strong front light so I noticed a grid pattern when looking at my files at 100%. I tried few things to minimize that without any amelioration. I supposed that it was a result of the absence of anti-aliasing filter. As last attempt, I change from RAW (that I always use) to JPEG and...no more grid! The camera correct perfectly the more than annoying grid artifact and deliver a perfect jpeg. Alleluia.
After intensive testing of coupling the two Fuji extension tubes together with my 56mm, I had to conclude that it's unusable for critical reproduction work. The ratio was really good, allowing framing a little bit larger than the 24x36mm negatives. But the sides and corners were always unsharp, independently of the aperture used. My goal is to «scan» a large quantity of B&W 35mm negatives using my x-Pro2. I now must turn to macro lenses to achieve the near 1:1 ratio with the pro quality I know I can get.
I have tried shooting pictures of my slides and negatives in many ways ( 60mm macro lens, adapted 100mm macro lens, slide repro-tube, enlarging lens on a macro bellows)
The results were always relatively disappointing.
Mileage might vary but don’t set your expectations too high. By the way the loss of focus on the sides might be cause by the curvature of the slide or negative.
Good luck!
It was tested by the guy behind Fuji vs Fuji blog, on a set of lenses, with examples: https://www.fujivsfuji.com/mcex-11-vs-mcex-16/
But I doubt the 56mm can be a very good macro lens. That's really not its purpose, and macro extension rings are sadly limited by the laws of physics. My advice would be to use a dedicated macro lens. For scanning slides, perhaps a 1:2 would be enough? In that case, buy the 60mm from Fuji. It's small, sharp, awesome and is now easy to be found used, thanks to the newer 80mm.
Otherwise, if you need 1:1, there are different options:
- Native lenses: Fuji 80/2.8 (but far too expansive if you just want to scan slides), Samyang 100/2.8 (cheaper), Zeiss Touit 50/2.8, Meike 85mm (I think it's new too)
- Adapted lenses from other brands. You can mount barely anything from Nikon, Canon, Tamron, Sigma... The old (and the new) 90mm lenses from Tamron are great 1:1 macro lenses (the oldest models are only 1:2 though), and can be found used in lots of different mounts.
- The Raynox adapters. You don't get the quality of a dedicated macro lens, but you get close and it's not too expansive.
Good luck!
Konzy
Edited by konzy
OK Guys...the results are absolutely amazing! After trying few macro lens options, I set my preference for a Micro-Nikkor 55mm 2,8 + tube. @Milandro, the curvature of the negative wasn't in the equation as my negative is maintained in place by an enlarger negative carrier. I can now confirm that my negatives reproduction are absolutely perfect. I compared them with some scans I get from a professional lab using a Nikon 5000ED scanner and mines are, way out, better with more tonalities and approximately the same pixel count when using the XPro2.
  Here are the useful information if someone goes the same way:
  • Only real macro lenses give good to outstanding results
  • Micro-Nikkor 55/2,8 is an extraordinary lens
  • I didn't test Fuji Macro because of high price and no need of autofocus but I believe it must be excellent
  • The negative must be flat so the use of an enlarger negative carrier is mandatory (or similar negative holder)
  • The use of a remote trigger is mandatory (I use a cheap remote with cable from Amazon)
  • My light source is an old X-Ray light (white balance isn't a problem with B&W negatives)
  • The «scan» time is calculated in seconds, not in minutes. Only depend of the time it takes me to change negative in the carrier! WooHoo!
  • Cost = zero/scan if I consider that I already have the XPro2 and a friend borrowed me his old 55mm with have a stiff focus ring so was never used. I made myself the reproduction rig with stuff I already had.
Seriously I was hoping the results will be good but they are stunning. When taking time to test and refine all the variables, it works great. Now the only things I still must do is «scanning» 20 years of B&W photography...
  • 2 years later...
you seem to be the right person to ask...
I'm having the same dilema, trying to scan my films (both 35mm and MF) with my xpro2 but without a dedicated fujinon macro lens. I bought a MCEX16 macro adapter but the pincushion distortion is awful. I didn't notice it with MF film but the combo MCEX16 + 56mm lens at working distance slightly crops the negative image so I couldn't really asses the issue so far (the only 'scanned' image so far had no straight lines). I use lomography Digitaliza film holders that do a much better job than regular flatbed scanner holders.
Is this all because of the adapter (or better said adapted lens)?
    • I had lusted for the X100VI for months. I am going to Japan in November, and after lugging my main camera and lenses around Europe for 25 days last month (Hasselblad X2D), and being 71, I decided it was time to get a new, affordable street/documentary camera. I logged on to BH and lo and behold, found a black on immediately. I have had it for three days and have some questions/comments: --I can't foresee ever using the video features. Is there any way to delete them from the menus? --I find the menus to be, to put it nicely, almost impossible to wade through and interpret. Reminds me a lot of my wife's Lexus--great car, poor user interface. So my question is: is there any way to delete some of the data presented on the LCD screen--specifically, along the top where I see "4K29.97" and "5h10m30s"? I assume the "1142" I see just to the right along the top refers to how many images I can record on my SD card? And there is a little window on the right that says "Shot". What does it refer to and can I delete it? --And one more if I may--IBIS. It looks to me like IBIS only works with the Video side of the camera, not still photography. Is that correct? I can't figure out how to activate it for still photography. If I can solve these issues it would be a big help. I've gone through the entire 360-page digital manual but I haven't found answers to these questions.   Thanks in advance, Steve
    • Brilliant! Thank you. LOCK function is really helpful.
    • Hmmm, I've noticed on my XF 150-600mm too, it's as if the profile corrections in Lightroom aren't properly matching the lens. I've not noticed it on any other lenses I own and use.
    • All of a sudden, I’m getting vignetting with both Fujifilm 18-135 and 55-200.  I don’t use lens hoods so that’s not the cause.  Thoughts anyone?
    • I am not getting any exposure indication on the scale on the left side of the screen when I install the XC15-45mm 3.5-5.6 lens on my X-T50. Is there a setting that might cause this? This doesn't happen with my 23mm f2 or 50mm f2.
