What are the thoughts on the Rokinon 12mm Vs. the Fuji 10–24 in terms of image quality? I understand that with the Rokinon you get a fixed focal length and no auto focus. I have the Fuji 18–135 and three M42 mount lenses: 28mm f2.8, 50mm f1.8 and 70-210mm f4–5.6. I think all I am missing is an ultra wide. I don't have the budget to drop $800 on the Fuji 10–24. If the Fuji is really worth the price, should I wait till I find a good deal on eBay?
Thanks all.
I use the Samyang/Rokinon 8mm fisheye, it's really super wide and very sharp just get it at ~1m focus and shoot no need for AF there. Plus you can use fisheye-hemi to straighten the vertical lines out to remove the fisheye effect.
What flash do you use in co-op with that? I'm switching from Nikon to Fuji and for Nikon I always used my SB-910 on TTL-BL or 1/32-64ish in M but I'm a bit lost in Fuji-land haha.
I use the Nissin I40 on the dance floor for direct flash at 1 stop under, and I use a half strength CTO gel to match colour balance.
The Rokinon is the value king, and a very different animal than the 10-24. Ultra-wide zooms are very handy - it's hard enough to make a good composition with an ultra-wide view - the zoom feature helps a lot. But I like small, fast primes on my Fuji.
