I'd love to see more examples like this. Thinking of getting into Fuji X., knowing I can easily adapt for landscape, architecture and street but mixed feelings about candid or posed portraits indoors. Particularly candid when subject is moving.
Nice shot!
FSP, thanks for posting this one. I can't tell if you bounced it, but my guess is you did. It froze the action nicely. Just the right amount of light. Do you also have the X-T10 and if so do you ever use the little built in flash for fill? (Just looked up the i40 and would be nice addition for many situations I'm in., 'tho have yet to purchase my Fuji.)
Yes, bounced with the i40 for that image. I had a wall fairly close behind me. I love how quick the controls are on the i40! I didn't want too much light bouncing back on my subject as I wanted to avoid overexposing the background with the video guy finding his way into my frame. I probably had it in manual as I rarely trust TTL during receptions so having the access to power so quick and easy is really nice.
I do have the X-T10 which I'm really loving. It is my second during weddings and my go to for personal stuff. I used the pop up the first night I got the camera just messing around. I'm not super knowledgeable on it but it seems like it would fill shadows on fairly close subjects well.
