Anybody else having problems with getting good starbursts with the 10-24mm lens - or is this scene just asking too much of the lens? These are SOOC JPEGs and the camera settings were:
ISO 800, 30 secs at f16 and f11
Might have found the problem (apart from me being an idiot)  gave the front element a good clean :-) Quick test shot attached - weather wasn't great today so it's not one of my best but the starbursts are much better!
I'm going to assume you've cleaned the FRONT and REAR glass?  Depending on what and how you cleaned it you may have left some streaks or smudges.  Shooting into the light source would cause that.  The other thing I can think of is condensation.
