My brand new X-T4 freeze now and then - anyone else same problem?
Hi,
I have a brand new X-T4. I have only used if for 2 days. Photo quality is OK in my opinion (at least some photos, some is very bad quality). But now and then my X-T4 has just freeze and it do not respond to any user input. Only way I have found to get out of it is to take out the battery and then turn on the camera again. Then all works fine again.
When I got the camera and lens (Fujinon XF16-80 mm F4 R OIS WR) I upgraded the camera to latest firmware (ver. 1.02) and the lens as well (ver. 1.05) before I started to use it.
I use two SD memory cards in the camera, Sony SF-G64T (UHS-II, V90) 64 GB (one such card in each memory slot).
I have a battery grip VG-XT4 with two NP-235W batteries but I have not mounted it on the camera and used it yet.
Anyone experience same problem that I have with my brand new camera?
I suspect the firmware but that is just a guess.
regards,
Bo (Sweden)
Edited by bem
You and I know that this is a similar comment/question to the one I asked and to which you replied.  I hope that adding another question will help someone with information find the questions and respond.  My issue is that my X-T4 "freezes" when turned on ever since I updated to v1.02 firmware.  The LCD is live but everything else is frozen and unresponsive.  After about 10 seconds the EVF and the buttons resume normal function.  I have used X-T1, X-T2, X-T3 and never had a problem updating firmware on any of them.  I always use an SD card for the updates.
I would really like someone at Fuji to acknowledge that the update has problems and let us know if there is a remedy in the making.  If I can't get some information soon I will be returning the camera and falling back to my trusted X-T3.
#v102fail
I was out some hours today Sunday July 12, 2020, the third day using my brand new X-T4. It frooze again after maybe an hour usage. I took out the battery and inserted it again and then it worked fine for the rest of the day. Out of 3 days usage it has froozen at least one time each day (some day several times) when using my X-T4. That is rather easily repetable in my humble opinion.
/Bo
Edited by bem
Hi,
I have now e-mailed "Fujifilm Nordic" support with basically same info I have written here.
It was not possible to phone them that I tried first, only e-mail is accepted.
So now I will have a support "case" with Fujifilm in Sweden.
If I get any answer and how the problem with my X-T-4 is solved I will post again here so You know.
/Bo
I have today got an answer from Fujifilm Nordic support (Swedish).
They tell me to send back the camera and request a new on warranty from the reseller Scandinavian Photo.
I asked them if I should try downgrade the X-T4 firmware from 1.02 to 1.01 but they adviced not to do that because it could damage the camera. So I will not do that.
I have replied and asked if they have checked with Fujufilm centrally (in Japan) if they have any reports of similar freeze problem I have with my X-T4 camera.
I have also asked if I should ask the reseller to install the latest firmware 1.02 in the camera before they send a new to me (if I claim a new on warranty), just to avoiid any discussion me as user has screwed up the camera with the 1.02 firmware upgrade. I'm waiting for answer on that question now. I also said to them, maybe it is a problem with firmware 1.02 and then even a new camera will behave similar with freeze maybe if it has 1.02 installed. I'm waiting for answer on that though question also from Fujifilm support.
/Bo
July 14th I got my new X-T4, I did also install firmware 1.02 (after unboxing) AND yes it also freezes from time to time. So far i just need to switch off then on for normal recovery. I have used my camera very little, i hope is only due to Firmware. Apologies I can’t add further insights. Will be following this forum. Cheers
Franky, can You check under the hatch for the SD card(s) if Your X-T4 is made in China or made in Japan? See photo below. Mine is made in China, and my X-T4 is just 6 days old (since I bought it brand new from the largest photo online shop here in my country). Sorry to hear that it is a freeze problem with your brand new X-T4 also.
I do not know how common it is for users to upgrade firmware in a camera like this, but it is sure easy and when one look at the new features (and fixes,  but Fujifilm do not tell what is fixed) I see no reason not to install firmware 1.02 in the X-T4 camera. It is so easy to make a firmware upgrade also and it was no problem at all to make the upgrade.
I have asked Fujifilm in my country if they think it is a firmware problem and I have also asked them to read this forum about X-T4 to see that it is more people that has freeze problem with X-T4 after upgrade to firmware 1.02. The answer I got  was:
"This is certainly nothing that should happen with this camera and I recommend You to contact the reseller to get it exchanged to another that works better."
I replied to them and asked if I should downgrade to firmware 1.01 but they said not to do that since it can damage the camera.
I also asked if they had checked with Fujifilm centrally (I was thinking Japan then) if  they had reports others had freeze problem with X-T4 with firmware 1.02 but they have not answered that and I do not expect answer on that. They have told me to get a new camera on warranty so I think that tells me what I need to know. But I asked them also if I should ask the reseller to install the 1.02 firmware for me but that has Fujifil support so far not answered. I also asked if I get a new camera and have the firmware 1.02 installed and same problem with freeze happen - what then? (one really suspect the 1.02 firmware in this case).
Is it any people out there with firmware 1.02 installed in a Fujifilm X-T4 camera that all is working fine with (no frreze or any other similar problem)?
I also want to add that when I yesterday was out to take some photos with my X-T4 the LCD suddenly was not working at all when I turned on the camera, only through the view finder I was able to see what I took photos of. The buttons worked fine but LCD dead. Later when I came home I put the camera on a table and let it sit for maybe an hour and then I turned the camera On, and then the LCD lit up as it should.
Another funny "Murphys law" happened when I was out in the woods with my X-T4 camera yesterday, when I was walking back to my car and walked on a small forest road I see a Badger on the road and I turned On the X-T4 camera to take a photo but nothing happed, the buttons had frooze...
/Bo
Edited by bem
I have now contacted the reseller Scandinavian Photo and I selected to use my consumer right to just return the camera and lens, and then get a another brand new X-T4 and lens (as a package, as I originally bought it first time) from them. That way I avoid any discussion on a warranty situation. The person at Scandinavian Photo was very friendly and said that will be fine do so so.
I want to give Fujifilm a second chance, but if same problem with the new X-T4 camera I will get next week I will have to switch to another brand since then my patience will be gone with a Fujifilm camera. I asked Scandinavis Photo if I could return everything then (also the accessories I bought like two chargers, two batteries, one hand grip, etc) and buy another brand of similar camera and they said that I could do that.
I hope my X-T 4 was just a "lemon" and a very rare defect camera that left the Fujifilm factory in China.
I also want to tell you this, that I received from Fujifilm Nordic support today July 16 2020:
"Of course it should not be any freeze and I have talked to one of our product specialists regarding this. It has nothing to do with the firmware, it seems to be a problem with the camera."
/Bo
Edited by bem
Another funny "Murphys law" happened when I was out in the woods with my X-T4 camera yesterday, when I was walking back to my car and walked on a small forst road I see a Badger on the road and I turned On the X-T4 camera to take a photo but nothing happed, the buttons had frooze...
/Bo
Hi. Mine was also manufactured in China... do they also manufactur from Japan? Should I get concerned??
Franky,
If production procedure and quality control is same in China as in  Japan I suppose it should not matter that it say Made in China on Your X-T4. But personally I would have prefered an X-T4 made in Japan for varios reasons. I have a new X-T4 including new lens incoming from the reseller next week since Fujifilm Nordic support told me to send my X-T 4 back (so many problem with my brand new camera during the 6 days I used it every day, took hunders of photos with it during that time). I had firmware 1.02 in my X-T4 camera and firmware 1.05 in my lens (Fujinon XF16-80 mm F4 R OIS WR). It is easy to see what firmware is installed in camera and lens. Just check on Fujifilm homepage.
Remember if you update firmware You must know this:
"FUJI EXPRESSLY DISCLAIMS ANY WARRANTY FOR SOFTWARE. SOFTWARE IS PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED OR IMPLIED..."
It is written so on X-T4 firmware download page on Fujifilm homepage.
To check the current firmware version:
Turn off the camera.
Turn the camera on while pressing “DISP/BACK” button to check the current firmware version.
/Bo
Edited by bem
I received from Fujifilm Nordic support yesterday July 16 2020:
I sent my X-T4 camera and lens XF 16-80 mm F4 R OIS WR back yesterday, as advised by Fujifilm Nordic support, and I will get a brand new X-T4 and new same lens next week from the reseller (I have talked with them on the phone), I hope it will work better this time.
/Bo
Edited by bem
I have got a brand new X-T4 camera and lens XF 16-80 mm F4 R OIS WR now. I have upgraded camera to latest firmware (it had 1.01) so it has version 1.03 now in camera, and lens had firmware 1.04 so I upgraded that to version 1.05 that is the latest firmware version for this lens I have.
So far the camera behave fine (no freeze). I will take some photos later today of weahter permit (rain is hanging in the air now).
Hat off to Scandinavian Photo (largest photo reseller in Sweden and one of the largest in the Nordic countries) that handled this problem with my X-T4 so great. I hope my new X-T4 behave normal now. Two "lemon" X-T4 in a row is very unlikely.
/Bo
Edited by bem
Hi there,
I have the same (or similar) issue here, camera freezing every now and then and the only solution seems to be to remove the battery.
To me it looks like an AF issue and it even seems that it was introduced with one of the FW upgrades 1.02 or 1.03. The error occurs extremely often when I use a remote trigger instead of the shutter button. When taking a picture the camera starts focussing (which by the way takes incredibly long now with the XF 16-55). Then suddenly it stops and the camera behaves like doing a long-time exposure (LED screen turning black, orange status LED on). There are two alternatives to solve this: either remove the batteries (power switch won't turn off the camera) or wait. After a minute or so the lense makes some focussing noises and the camera "comes back". Hate to say this but it seems that Fujifilm's production standards seem to have reached an all-time low...
Edited by junOlive
junOlive,
So did Your X-T4 behave normal before the camera firmware 1.02 or 1.03 was installed?
Do You have latest firmware installed for the Fujifilm lens You use?
I suggest You e-mail Fujifilm support with a detailed description so if it is a firmware problem they can perhaps fix it in a newer firmware version sometime in the future?
/Bo
Edited by bem
I purchased an X-T4 about two months ago.  After I configured it to my liking it froze a couple of times.  By freezing I mean that no controls/buttons would function and the EVF and LCD were also frozen.   I could only get it to work by removing the battery and then turning it back on.  That would solve the matter.  I started changing one setting at a time to see if I could determine if any settings were causing the problem.  I have no idea if it is a coincidence or it has solved the problem, but once I set all my film simulations’ “Clarity” settings back to zero, I’ve not had another incidence of the camera freezing.  That was three weeks ago and I’ve used the camera several times.  Clarity may have nothing to do with the freezing, but as of this writing, it has functioned properly every time.  By the way, I do have the latest firmware loaded.
On 8/2/2020 at 12:28 AM, bem said:
junOlive,
/Bo
Hi bem,
Yes all firmwares are up to date. I strongly suspect firmware 1.03 as the culprid because I haven't had such problems in studio shootings with the X-T4 before. When I tried last time it were about 3-5 shots before the camera froze - repeatedly. Maybe its also worth having a look at temperatures...
I'll contact Fuji FPS and will report here when they tell me anything substantial.
When I asked Fijifilm support in my country about the possibility to downgrade to an earlier firmware version for the X-T4 they adviced me against it, they claimed the camera could be damaged. So it seems You are stuck with firmware 1.03 for now, if you want follow the answer Fujfilm support gave me.  I suppose it is bugs here and there in all camera firmware, at least one can read sometimes in the release notes for Fujifilm camera like X-T4 "Fix of minor bugs". Personally I would like to know what the minor (and probably some times major) bugs are before I install a new firmware.
/Bo
Edited by bem
hi guys, i'm emi from italy. I'm searching for a solution to the same problem i've read here.
My brand new xt4 sometimes freeze. I shoot video, and as you know, if this happen during an event, it's the death.
Even if i'm in still or movie, i have this problem random
3 days ago, i had 3 times in 1 hour.
I use last firmware, 1.03, sandisk 170mb 64 gb. Fringer adaptor with latest firmware and sigma lens for canon 18.35.
I hope it's only a firmware problem, i don't wanna think i have to ship the camera for an rma.
I upload a video to this problem. I hope we can find a solution very soon.
Xt4 camera freeze
Same situation with my new X-T4.
The camera freezes occasionally - sometimes when switching something on it (e.g. from Movie to Photo Mode or back), sometimes after taking a photo and sometimes it won't wake up again after going into Sleep Mode...
The one and only solution to get my X-T4 working again is to take out the battery and put it in again.
I tried several SD cards - from old ones to brand new UHS-II U3 with V90 standards...nothing changed.
And when I switch between the XF 16-80mm 4.0 lens and the 23mm 2.0 - nothing changes at all.
And yes - I got the latest firmware installed on the X-T4 and on the lenses.
Sadly it is not possible to reproduce the error - it occurs randomly.
Never had such issues with any other cam I owned...not matter if Nikon, Canon, Panasonic or Olympus.
I am really disappointed 😞
Edited by wernschi
The response I received from Fuji support was that it very much looks like problems caused by a defective SD card (which I'd personally rather rule out given these Lexar 2000x cards work fantastically in an X-T3).
However, I found an interesting post on Facebook where someone reported exactly the same behavior I had observed with my X-T4. In the reported case Fuji support narrowed the cause down to the Godox X2T-F wireless flash transmitter that was mounted to the X-T4.
Though not really having tested other scenarios yet, interestingly enough I've been using the same trigger when having the described problems. So maybe its a hot shoe thing. The trigger itself seems to work fine on other Fuji cameras. Has anyone of you guys had mounted something on the hot shoe while experiencing these freezes?
Edited by junOlive
All X-T4 cameras we buy in Europe are made in China. Fuji only delivers 'made in Japan' X-T4s to the USA to bypass the high trade tariffs imposed on Chinese products. In fact, I've been told (but I'm not certain about it) that these cameras are also mostly made in China, but then shipped to Japan for some final assembly and packaging. Just enough to qualify for the 'made in Japan' stamp. Today, only the X-Pro, X-H1 (until a few months ago) and the GFX are actually build in Japan.
As for the SD card issues, that is a recurrent issue with Fuji cameras. The X-H1 had real issues (incl. lost images) and we've seen multiple reports of X-T2s, X-T3s and X-Pro3s having issues. Most of them are solved in firmware updates (the notorious 'various other bugs') but for the X-H1 I've experienced continuous problems up to date (albeit less than when the camera was first released).
Best advise is to stick to the brand and type of SD cards that Fuji recommends and hope for firmware updates. In case the camera frequently freezes, I would always ask for a replacement.
    • Well done! p.s. Welcome to the forum.
    • I think reassigning the exposure compensation dial a good start.  The 520 page online manual should be condensed along with the number of setting options. Maybe they could have multiple firmware options for the X-E5; a pro-version, a photo enthusiasts version and a point and shoot version.  I love my X-E5 photographs but as a typical senior, with declining cognitive skills, I’m sorry say that I find the current singular version unnecessarily challenging.
    • I was told the GFX 100 II couldn't do this so I decided to test it:
    • You appear certain you intend to use this lens for astrophotography. Hmmm. Are you willing to consider the suggestion you will be better off trying the XF-500mm prime lens instead? Simply put, prime lenses are way better than zoom lenses for astrophotography while the XF 150-600mm is great for terra photography. 1.) The lens hood’s connection placement on zoom lenses is right on the very edge of the lens body. This is a loose connection that allows any tiny stray light to enter the lens and then bounce around the many lens element groups, ending up on the sensor, causing all kinds of gradient troubles. For terra photography, cough, cough -daytime photography- cough, cough, this is not a problem because that little stray light is lost among the bright daytime backgrounds. Prime lens hood’s loose connection placement tends to be further up on the lens body, so stray light is usually not able to bounce into the lens so easily. 2.) Weather changes affects the lenses. All lenses can have focus creep even when pointed horizontally, cold and hot causes the mechanical parts to expand or contract differently, but especially when pointed up in the sky because gravity also pulls on the parts. Zoom lenses additionally have something called ‘zoom creep’ which you can figure into the issues you will face during your sessions. Essentially, you need to refocus when it gets cooler during the night. If you are determined to try this lens anyway, best wishes!!! It is possible to make a homemade lens hood. There are plenty of companies that sell dew heater straps fitting this lens to keep it from frosting over during your sessions. Also, you can find Bahtinov Masks or Carey Masks that will fit the lens. These make focusing on the stars much, much easier and are not difficult to learn how to. Or, if your camera body is one of the top line bodies that Fujifilm has released the SDK for, various astrophotography apps will take the live view and help you focus. Say X-T3 but not X-T30, etc. p.s. Welcome to the forum.
    • I had no problem finding a spot at the beach this afternoon.  Was not crowded at all. GFX100 RF.
