18-55 ~ $700
16-55 ~ $1200
nothing personal just business.
You're entitled to your opinion of course, but the reason the 16 - 55 costs so much is because it's a premium lens.
Many photographers, including myself, appreciate both the extra 10 degrees of diagonal view, but also the constant aperture. It's a heavy lens, it's an expensive lens, but it's also a most excellent lens for those who appreciate it's overall quality.
and I totally agree with you. I consider 16-55 way better lens and I find 16mm much more interesting than 18mm I'd just told about my desire to have a choice. Here we have to buy either a body or an expensive lens. That's it.
I suspect the reason they have included the 16-55mm as a lens kit is for the following reasons.
1) Many people have held off buying the 16-55 because it was not stabilized and because it was a big lens, the X-H1 solves both those problem by having IBIS and having a bigger grip so a lot of people may now take the plunge.
2) Currently the 18-55mm has been sold on so many cameras and then switched that you can pick it up on Ebay used for around £200-£250 on any given day, giving away more of them is only going to drive the price down further and anyone who wants one with there X-H1 will just buy one s/h plus body only package much cheaper than in any potential bundle.
3) The 16-55mm is seen as being the PRO zoom and the X-H1 is being marketed as the PRO camera in the line up.
4) Many buyers of the X-H1 will probably already own a 18-55mm, buying the bundle with 16-55mm is appealing as they can compare lenses and probably sell 16-55 for no loss, but,,,,, they might keep it, sensible marketing. Or they sell the 18-55 further reducing the overal cost of the X-H1 kit.
Conclusion I suspect that the 16-55 and 18-55 price is going to drop a bit over the coming months along with the X-T2 price :)
    • Hey everyone, I am new to the fujifilm system, and I just received my X100vi about 15 days ago, and yesterday I noticed that ISO and exposure dials are acting up. I spent hours watching YouTube videos and reading forms without finding any solutions. Using ChatGPT or Gemini also didn’t help. My issues are the following: If I want to set my ISO at a specific value then the camera LCD/EVF shows a totally different value. For example, I have shutter manual, aperture manual and ISO dial at 6400, the camera shows ISO at 4000, when I take pictures it will show ISO at 4000 and not 6400. When I try to choose another ISO value it will skip some of the available values that are shown on the dial. Another issue I am having is when my exposure dial is not set at specific value, then I cannot set ISO to Auto no matter what value I select on the dial. If I do select the different exposure compensation values, then I choose A for ISO, the camera will activate the front commend dial to manually change ISO values. To get in Auto ISO, the shutter speed cannot be set in auto and the ISO dial should be set at 125, when I turn the ISO wheel, it seems like the numbers are misaligned by one value, If I put the dial on A with shutter speed manual, then it will trigger the front commend dial. The other issue that I am having is when I have Aperture, shutter speed and ISO on manual, If I change the exposure dial compensation + or - , it actually changes the exposure of the picture as well as the ISO value, which as I understand, if Camera is in full manual, the exposure dial should do nothing. The last issue that I am having, if I do have ISO in manual at a set value, and adjust exposure compensation dial, it alters my ISO instead of my shutter speed or my aperture, even though ISO is in Manual and the other two dials are in Automatic. I am not really sure if all of this is by design and I am just not understanding how everything works together, but it seems really odd how everything changes. Resetting the camera settings didn’t help.
