Camera does not record RAW file!
I told you the solution. Rename the LUT without special character -
Do you have the URL for that forum where there was a solution? Don
I found the solution on an other forum. You have to change the name of the LUT. The problem come from "—" caracter or I don’t remember wich on -
Hello, Delighted that you posted this as I too am having issues. I own an X-H2S shooting in FLog2C. I have tried a myriad of combinations of CSTs (with and without using CineonLog) and color management settings to get these FujiFilm LUTS to work. As yet, I am yet to be successful. There must be a gap somewhere in my understanding. Hopefully someone can help us out. Don
