Not going to go all political here but this is a "hate" group. Nothing more, nothing less.  I refuse to acknowledge them.  As a matter of fact, at a recent event three individuals showed up wearing BLM shirts (they had just come from a rally) and I asked them to leave as it was a kids party, not a political event.
