Q-button suddenly stopped working
By ruralrelic · Posted
This is probably very obvious, but I am a little confused! - Presumably, when using the film simulation dial on the X-T50, the Custom Settings need to be set at 'Nothing Serlected@' Is this correct? Thank you -
The Laowa 65mm macro seems well regarded, I'm sure it would serve you well. Another potential choice would be the Fuji 30mm macro, but it would have a closer working distance and might make lighting your subjects harder.
It does look strange…, but no, it is part of CSX’s (a railway company) maintenance equipment.
Example: I am using a custom recipe, and I then use the film simulation dial to select a simulation. Are values from the custom recipe carried over, such as highlights, shadow, and white balance etc.? After studying the articles in Fuji X Weekly, this appears to be the case If you set a recipe on one of the C slots its settings will be applied to all the film simulations on the dial. The workaround is to use your 'standard' recipe at C1. Please clarify this for me . I would have thought the film simulation dial would have no input from other camera settings. Thank you - Very Confuded!
