X100V Front Command Dial will not change shutter speed
If the spots are in the same place every time then its likely a dirty sensor - you can buy a sensor cleaning kit and do it yourself or take it in to get cleaned professionally.
Hi everyone, I’m hoping you can help me with an issue I’m having with my images. Every photo I take with my Fujifilm X-T2 has visible spots on it (as shown in the attached photo). Because of this, I have to spot-heal all my images in Lightroom just to remove the spots, which is very time-consuming. I’d really appreciate any advice or suggestions on what might be causing this and how I can fix it permanently. Thank you so much for your help!
Like jerryy said lithium batteries are shipped partially charged. Do you have ibis turned on, and is it set to continuous or shooting only? If continuous that could be the noise you hear. I’d also contact Amazon on the shutter count and missing wall plug.
Normally, lithium batteries need some charge to keep them healthy. Try to never let one of these drop to zero charge level, that can cause it to short circuit or be permanently disabled. Have you not contacted or heard back from Amazon yet? I think your troubles will disappear once you get in touch with them.
An update on this , I got an email my from regional fujifilm support saying that it should be zero, so now I’m not sure what to think.. I sent them email again asking them if this qc claim can be true, but no response yet. A lot of posts on internet say that their cameras came with some photos taken due to qc, and also ChatGPT tells me fujifilm support is wrong … I wonder if I should contact fujifilm global support. A couple more questions that trouble me: Camera came with battery at around 75% is this normal? Shouldn’t it be 0? Also I hear a constant low humming /fan like noise from camera. It stops when I enter photo viewing mode. Thanks
