Hello all! I'm Henry and I recently switched from another brand to Fuji X-T4.
I have a problem with the shutter speed 'T' setting. According to the manual, I should be able to use the rear command dial to change the shutter speed but in my case that's not so. With the shutter speed dial at 'T' the actual shutter speed is locked at 1/25 of a second and I can't alter that - not by rotating the rear command dial or anything else for that matter.
Also, in manual mode I should, it is said in the manual, be able to alter the shutter speed in increments of 1/3 EV using the rear command dial. This, too, is not the case with me.
The rear command dial works fine in other areas, so it's not broken or anything.
Does anyone have any idea what the problem here might be? Some settings that I have possibly changed or something.
Thanks in advance!
/Henry
I can adjust Shutter speed with rear right dial. I have set it in menu settings I want to adjust shutter speed on that "wheel" (to right decrease value, to left increase value). On front wheel on right side on X-T4 I can adjust ISO (also Apperture and value on that wheel, just cklick on the wheel and then rotate to select between them and confirm with click on wheel, select desired value. I mostly use manual settings for SS (Shutter Speed), ISO and Apereture ("F"). I have the right horizintal dial for shutter speed on top of X-T4 set to "T" (the little white dot is towards T) and then has that locked with press on top button so the dial is locked.
Try read the X-T4 user manual some to get You on the right track to solve the problem that is with Your camera now that You can not select higher Shutter Speed (SS) then 125. Check in the camera Settings:
SET UP
BUTTOM/DIAL SETTINGS
COMMAND DAIL SETTINGS
Check what is assigned for the rear right dial (wheel).
  • 3 years later...
    • Thanks for the replies. I didn’t explain myself properly before. So this is what I am concerned about. I have an X-T4 and recently purchased a mint 16-55 mk1 lens. Checking on YouTube I saw videos saying that this lens does not fully ‘resolve’ with a 40MP sensor camera and I had been looking to upgrade the X-T4 to an X-H2.. It looked like there was slight blurring particularly in areas near edges of the images.  I guess some YouTube influencers are always looking for the next subject to create a video on, and could publish lots of videos about pixel peeping. So my concern is whether this is really an issue? I do not want to buy the latest Mk2 lens, so if there is an issue I would stick with the X-T4. Any user experience on using the X-H2 with older lenses such as the 16-55 Mk1 would be appreciated. many thanks Graham
    • Hi I can not select anything else from drop down menu ( where you would select video) apart from still image. Has anybody has that problem ?
    • I am about to PX my X-T4 for an X-H2. I have the original 16-55, plus 18,23 and 35 primes. i read there is an issue using the original 16-55 on the X-H2 with the.40mp sensor. is that something I need to be particularly concerned about. I am just an amateur photographer using Fujifilm’s for landscape and holidays. any advice appreciated. many thanks Graham
    • I use the Thinktank Retrospective bags with a similar lens complement and it too is mostly unpadded (padding in the dividers). I find it works well, and is of a similar design to the Domke.
    • Perhaps look for a secondhand XF 23mm F2 and a secondhand XF 56mm f1.2, use those for six months or so and see where you feel you are missing something. The 23mm (35mm equivalent) is a popular general purpose lens and can be used successfully for most general photography. The 56mm (85mm equivalent) is a popular short telephoto and portrait lens, giving shallow depth of field when used at wider apertures.
