Firmware Fix for Q button on X-T30
Thanks for all the comments and suggestions. What I've done is gotten the Firmware 1.02 upgrade, then turned off the Q button and transferred the Q menu to the Fn button next to the shutter release. Works like a charm.
By the way, this little X-T30 with the 18-55 kit zoom is an amazing camera!
Edited by rpkphoto
I also have issues with accidentally hitting the Q button. The firmware did not solve the issue since no matter what you make the Q button do you are still going to hit it accidentally.
The only fix for me would have to be along the lines of a double click being needed to activate the Q menu.
Bottom line its very poor ergonomic design by Fuji- who should know better
Spoils an otherwise excellent camera.
When I first got my XT30 I had the Q button problem, but I refused to have a useless button on my camera and have just learnt to avoid hitting it all the time. I've updated to 1.02 and I think they have added a slight delay, in that the button must be held down for a few micro seconds before it activates the Q menu. In any case I no longer have the problem.
