Nice. Mine has arrived to Canada last night. I should receive it by 3-5 business days. Hopefully the wireless trigger will follow really soon.
Looks like the triggers are not available yet for Fuji but as soon as they are, that will be great.
Flash seems well built, not too big. Only takes 2 x AAs. Zooms with the lens. Need to try it out properly, but first impressions are good.
Sent from my ONEPLUS A3003 using Tapatalk
