Best cheap flash with ttl and AF assist for X-T1
By Steve Crook · Posted
Prior to this I had a camera that would connect to my Oneplus12 (Android 15.0.0.840) via bluetooth. I did the update all appeared to be well though I didn't check the bluetooth connectivity. Then I saw the 4.3.1 bugfix update and tried to apply that through the X app ( version 2.5.1(1) ). Was told I needed to re-pair my camera. Tried to and couldn't. At the point where I have to confirm the security codes I confirm the pairing on the phone, then on the camera and the camera display sits waiting for the pairing confirmation and there's a message on the X App that tells me there was a communication error that prevented pairing. Eventually camera disconnects from phone. If I try confirming the camera then the phone I end up in the same place. I've deleted and reinstalled the app, restarted the phone. Nothing seems to make any difference. I did the update to 4.3.1 via SD card and nothing appears to have changed W.R.T bluetooth. Any ideas? -
By phantomcamera · Posted
Hi everyone, hopefully there is is someone out there that has experienced this before me and has a solution I've recently purchased a Camera Foundry Cineback in an effort to streamline my setup a bit for video recording. Before I was using my XH2s and a Tascam Portacapture x6 with their own internal power sources but with the Cineback I'm able to connect the two devices to the same battery via USB-C. My problem is discovering that when both the XH2s and the X6 are plugged into that shared USB power source, I get a clicking/popping noise on the recording and headphone output from the XH2s. The output from the Tascam is clean on both the headphone out and the actual line output I'm using the feed the XH2s. This isn't necessarily confined to the Cineback device either. I have a USB power supply that plugs into the wall with dual USB-C outputs and I get the same audio issue when connecting the Tascam and Fuji to run off that power souce. If I use two different USB power supplies, either a second "wall wart" or running one from the Cineback source and the other from the wall, I have no issues. I've also tried replacing my Tascam recorder with a Zoom F6 to see if there was an issue with the Tascam device, but I get the same problem with the Zoom F6. Is this an issue with my XH2s? Some sort of ground loop issue? Any help would be appreciated! -
By matty_fuji · Posted
Greybeard - you're a legend. Thank you so much for taking the time. I've changed to Electronic Shutter and it solves the issue. Didn't realise the mechanical was limited to 2000ss. And yes, you're correct about the ISO too. Thanks again! -
Hi, just got a Tamron 18-300m yesterday and found this forum. It worked well on my X-T2. On the X-T4 it would not focus between 60-299mm. I bought if for an Iceland trip and was mad. Happily i had some hope after reading this page, I have changed the settings to use a Zone AF and turned off face detection. It now focuses on the X-T4. Both lens and X-T4 are on the latest firmware. Just joined the forum, not sure if this is the best thread to ask on, I searched. The Tamson 18-300mm seems very unstable at 300mm, I know its long, are you guys using a tripod at that length for stability? I am planning on taking it to iceland for tele shots, but if its this unstable at 300mm, i will have to get a lens collar and another tripod for it to get sharp images. Does anyone have any experience / advice in the field with this lens? My old Canon 70-300mm IS lens seemed more stable hand held. I dont want to come back from Iceland after using it and binning all the shots from it due to the IS not being great handheld. Cheers, Steve Update, seems the focus went on each body again. turning it of and on again on the xT2, and it’s working again. I wonder if it cannot handle a focus mode switch? Or some other setting changes while it is on? Did anyone check this? obviously it’s not acceptable, but it seems to be linked to some change during use. If I work it out, at least I can mitigate its problems. Steve
Can the GFX100ii shoot video undercranked, for example 3 fps on a 24fps project frame rate? Step printing is something we use on many projects, so it'd be good to know before buying the camera. I can't see anything in the manual. Sounds like the XH2-S can do this, though again, I'm not sure. Thanks folks.
