There is anybody who miss a 300 or 400 mm F4,5/5,6? A lens not expensive at maximum a one thousand of euros?
Yes it is possible to use the 200mm f2  with focal duplicator, but the solution is not cheap, because 200mm F2 is not for everyone.It is expensive
I shoot a fair amount of  motorsports and 200mm is  just a tad too short and  money is  even shorter since retirement . Ideally, I'd love to see something in the range  of 270mm  to 300mm. F4.5- 5.6 would  be just fine so long as the lens has good contrast.
Edited by caterham
needed more words ;)
