Hi - I got a X Pro 2 for Christmas and have jus set it up.
Put the battery in  and my two cards (SanDisk Extreme PRO SDXC Memory Card up to 95 MB/s, Class 10, U3, V30 - 64GB) and I formatted them both.
When I then tried to take a photograph it would not take one ?
The display work and I've put the language and date in there too?
Any ideas please?
Edited by Sharon Harrison
Something else you could check: go into the AF&MF menu, then to Release/Focus Priority on p.2 of that menu. If your AF-S and/or AF-C priority selection is set to "Focus", then the camera won't take a picture unless the image is properly in focus. (I keep mine set to "Release" for both, even if it means a few out-of-focus shots).
It might also be an idea to re-format your cards before trying again.
Any ideas please?
The camera turns on?
If you turn on you should verify that the cards are not blocked. Sometimes the insurance slips without a warning.
