I have a question.
Why is it that - according to one member here, not that I disagree with his premise - Tapatalk add-ons from those using their phones to respond to threads are annoying and unnecessary.
Yet that same member gets to repeat his lengthy complaint, repeatedly, sticking it in our faces far more frequently than those Tapatalk contributors who more often than not probably don't realize what they're imposing on others by doing this.
People need to get a life. And a sense of perspective.  :o
