Just to clarify a little: The Fuji lenses are metal (aluminum) clad and with metal (aluminum) mounts (although I think the 50-140 has a brass mount), but they are plastic on the inside. That is, the build quality is better than your usual modern plastic lens, but not as good as vintage all metal lens construction. Since the metal mount is screwed into a plastic internal frame, that's usually where they break.
Edited by kimcarsons
