Most Popular Buy: Headphone Adapters (and Batteries)
You may have noticed that the Fuji X Forum sometimes links to Amazon. This helps us to fund the forum – and gives us interesting insights what you Fuji X Forum visitors are interested in. I took a closer look at what products where bought from Amazon in recent months after having visited our forum.
Some of the Most of the popular articles are obvious:
  • Cameras
  • Lenses
  • Memory cards (see list below – Fuji X users apparently LOVE Sandisk)
  • Batteries
  • Accessories – you'll find some of them below
About some popular articles I was first puzzled, but then I found the reason in the forum.
Top Article: Headphone Adapter
Believe it or not: The most popular article in the Fuji X Forum is this:
Motorola USB-C to 3.5mm Audio Headphone Jack Adapter Cable
How come? I searched the forum and found this discussion:
» Fuji X-T4 Headphone Adapter Part
… in which a member was looking for the best replacement for his Fuji X-T4 USB-C headphone jack adapter. The one he had didn't work and thus he was asking for advice. Obviously a lot of X-T4 photographers had the same problem – making the Motorola Adapter the most popular accessory here in the forum…
Next up:
Batteries & Chargers
Fujifilm’s original batteries (NP-W126S and NP-W235) are most popular, but a lot of cheaper alternatives and dummy batteries are selling well too:
Top Cameras
The three flagships (and the X-Pro3) are your favourite Fuji cameras:
Top Lenses
Four Fujinon lenses and a Viltrox prime are the best seller lenses:
Accessories
Haoge's accessories seem to meet your taste
SD Cards
Memory card best sellers are SanDisk UHS-II cards:
Do you have other recommendations for Fujifilm photographers?
Feel free to share them here!
Disclaimer: The Amazon links in this post are affiliate links, which allow me to get a small share if you buy from Amazon.
    • I think I know what you mean now. I noticed the STRONG grain setting in the raw file when I was using X Raw Studio. On other software like Windows Image viewer or Lightroom the grain effect is not showing at all. Mystery solved!
    • Its difficult to imagine this could be anything other than a faulty camera. You seem to have done all the tests to eliminate other causes.
    • Hi Last week during a reportage, I shot bursts from about 5 fts with one of my two X-T5s, for a total of about 100 photographs. I had mounted a Fujinon XF8mm. Everything seemed to proceed regularly without any sign of problems. When looking at the sequences in the car I realized that many photos were completely black, that is, as if I had taken with the cap in front, alternating with some perfect ones and others completely white without any detail. Back in the studio I loaded them onto the Mac and noticed that of a sequence of around 100 photographs, 49 were completely flawed, that is, almost all of them were completely BLACK and some were completely WHITE. The problem was present both on the photo of the Slot 1 card (RAF) and on the Slot 2 card (JPG) in unison, so much so that I discarded the hypothesis that it could be a problem with the memory card. So, to recap: the errors on the 49 offending photos are exactly the same, for both cards in RAF and JPG. After turning the machine off and on again, it started working perfectly again, so much so that in the following days I carried out other jobs, even with gusts, without any problem. Obviously I am waiting for a response from the support to which I sent the offending sequences. I would add that if I analyze the EXIFs of the BLACK or WHITE photos, the values and data that appear are completely normal, that is, they report exactly the same information as the photos that came out well, as if nothing had happened. 1) Before each job, I always format the cards in the machine, with the specific function that can be called up from the menu and quick keys of the XT5 2) The XT5 has Firmware version 2.03 3) The Fujinon XF-8mm lens Firmware 1.00 The problem has manifested itself, for now, only once, intermittently, that is, some faulty photos alternated with perfect ones. In the following days, on the advice of the assistance center, I put on the intervalometer and shot the camera until the card was full for a total of 1600 shots. No problems, everything is fine. What do you think about it? Has anyone had this problem?
    • In manual, exposure compensation is meaningless and the dial doesn't do anything. The exposure compensation display on the rear screen and in the EVF however changes its purpose slightly, and effectively becomes an old fashioned light meter / exposure meter. As you move the camera, it changes dynamically showing you how over/under exposed you are. It is not doing anything active - not changing a setting - simply passively showing you the result of your manual settings of F/SS/ISO you have set on the resultant exposure. You do not want to disable this. Manually change F/SS/ISO until the exposure comp scale reads 0, and you will have a perfectly manually exposed picture. You can, of course, use it to accurately over/under expose by thirds of a stop, depending on your artistic intent.
